code P0430
Old Dec 21, 2016 | 08:59 PM
Rastan's Avatar
Rastan
Default code P0430
Hello forum members. I have a 2003 Z-06. I have been getting a P0430 code for catilyst below threshold bank 2. I know bank 2 is the passenger side. I have tried that Catty clean gas additive but the check engine light has come back on twice in 40 miles since. Any help would be great.
Old Jan 6, 2017 | 08:22 PM
vetteguy8899's Avatar
vetteguy8899
sounds like a failed cat. if you have access to a scanner, moniter the upstream and downstream bank 2 o2 sensors. the upstream should be switching rapidly while the downstream should switch much slower. if the downstream 02 is switching rapidly, that usually indicates the cat has failed
Old Jan 6, 2017 | 08:39 PM
zachaeous's Avatar
zachaeous
I had the code come up after longer drives. I went with the spark plug anti fouler and the code has not come back since. Cost less than $8.00 and my time to take care of it.
https://www.corvetteforum.com/forums...ot-needed.html
Old Jan 7, 2017 | 11:35 AM
vetteguy8899
gotta like that!
To code P0430
