I got these injectors with a package deal with a new walbro 255 fuel pump, these injectors were supposed to be Bosch 54lb injectors. The problem is the ##s were taken off and i can't find any info on them to try and tune the car with them, so i had to use my stock ones for now..
If anybody can help on what these injectors are, i would greatly appreciate it..
Tough call without serial numbers as most of the fuel injectors will flow differently and the shell looks the same. Only real way is to have them flow tested. Its expensive at around 25-28.00 a piece. Best bet is to send one in for the service and have it flow tested and they can tell you what it is. Why would they file off the serial is beyond me.
If I was in your shoes I would start there or just ditch them and buy ones you know are what they say they are. I used RC Engineering to test an injector I bought from fleabay that were advertised as 30lb and ended up being 45lb, the same 45lb ones had the same color shell, same manufacturer except the serial number was different. Good luck in any method you use.
