Help with a diagnosis on transmission
Old Jan 1, 2017 | 04:27 PM
topdown01's Avatar
topdown01
Default Help with a diagnosis on transmission
Happy new year everyone!
I just pulled the rear end to install a new clutch...and saw the leaky butt syndrome. Found good info on that to replace the seals. Once I pull the entire assembly out I saw something at the front of the transmission that I was not sure about...it's a manual transmission, 38k miles...and in the picture you can see that there appears to be a leak between the transmission and torque tube...I looked the window of the torque tube and nothing seems odd but I am not familiar with this at and was wondering get if anyone might be able to help me understand what this might be...
thanks,
Kevin
Old Jan 1, 2017 | 05:49 PM
Rob 02's Avatar
Rob 02
My A4 looks like that with no visible signs of leaking inside. No wet drips or fluid loss.
I think mine is road dirt from the way the wind blows under there.
Old Jan 4, 2017 | 12:54 PM
topdown01's Avatar
topdown01
Thanks Rob!
To Help with a diagnosis on transmission
