Targa Roof Leak
Old Jan 4, 2017 | 09:20 AM
huesmann's Avatar
huesmann
Default Targa Roof Leak
I have a leak in my targa roof, right at the point where the roof rubber seal meets the windshield rubber seal—see attached pic. Red arrow shows a droplet of water, and the blue squiggle shows what I believe is the path is takes to get there. I think the water comes in through the gap between the two seals.
Ideas on how to seal that up?
Old Jan 4, 2017 | 04:41 PM
C422's Avatar
C422
I was legitimately just searching for this problem. Hoped there was a solution XD
I think, personally, that I need new seals around pretty much the entire cab
Old Jan 4, 2017 | 10:10 PM
CorvetteFrankie's Avatar
CorvetteFrankie
Mine leak too. 2000 model year. Got a reputable body shop near me that is going to redo all my seals and weather stripping. Good luck sir
Old Jan 5, 2017 | 11:05 AM
huesmann's Avatar
huesmann
That must be costing a fortune. Some searching indicated that some silicone dielectric grease may help. Ima try that first before shelling out a bunch of C-notes for new weatherstrip.
Old Jan 5, 2017 | 02:42 PM
You can try some dielectric grease and see if conditioning the weatherstripping will help. You may also want to try adjusting the fit of you targa top and also adjusting the window tip in to where it fits tighter against the weatherstripping. I have a number of Word files that covers these areas and if you would like a copy of them, just PM me your e-mail address.
Old Jan 5, 2017 | 02:45 PM
CorvetteFrankie
It's a small price to pay to renew my 17 year old car. I've been dumping tons of money on the car since I bought it a few months ago, and am still nowhere near the cost of a used c6, or the down-payment on a c7 haha
Old Jan 6, 2017 | 10:35 AM
huesmann's Avatar
huesmann
I think I already have those, thanks. Do any of those adjustments fit the targa rubber more tightly into the A-pillar rubber?
Old Feb 25, 2017 | 12:22 AM
vettelover8306's Avatar
vettelover8306
you can adjust your glass up to the weatherstrip remove the door panel you will see two bolts that hold the glass loosen the screw and move the glass up a little ..tight the screw and close the door with the glass up... Do the same with the other screw.. If you were in my city i could help you miami fl
To Targa Roof Leak
