cold air intake
Old Jan 6, 2017 | 08:14 PM
vetteguy8899's Avatar
vetteguy8899
Default cold air intake
im sure this has been discussed a million times but what are you guys recommending for a good cold air intake without breaking the bank? thanks. sounds like the vararam is nice kit but has clearance issues.
Old Jan 6, 2017 | 09:22 PM
grantv's Avatar
grantv
Once or twice...
Some swear by the Vararam, the Honker is another popular unit. I prefer a standard open element unit such as supplied by AFE, Airraid, etc., with a dry synthetic (non oiling) filter if possible.
Old Jan 6, 2017 | 11:10 PM
Friscojim's Avatar
Friscojim
I've been eyeing up the Mid America MAM $400 kit that includes a new mass air flow sensor - haven;t seen anyone who has one that has reviewed it though -
Old Jan 6, 2017 | 11:39 PM
The Callaway Honker and Vararam are about the two best cold air intakes. The Blackwing is a good air intake, but it is not a cold air one.
Can't comment on the clearance issues with the Vararam, but many reports have been made about the difficult of the install, especially all the parts fitting tightly together.
Old Jan 7, 2017 | 10:38 AM
Gordy M's Avatar
Gordy M
The newer VeraRam intakes are much better fitting than the older models. While it can take time if you have never worked on the front end before, it should fit without any issues. Unless you are exceeding 450 hp forget about replacing the MAF. When everything is done and you have about 50 miles on the new set up, then get a good scan/log tune and TB tune. It will really wake the car up, especially in the 2000-5000 rpm band. Many have used COW with excellent results.
Old Jan 7, 2017 | 11:30 AM
vetteguy8899
thanks to all for the great info. And Gordy, you answered my next question about the tune. I will research the COW tune so far all is stock other than the cat back slp loudlouth. a cold air kit is next on the list.
Old Jan 7, 2017 | 11:35 AM
Friscojim's Avatar
Friscojim
thanks - the more I researched the MAF on the MAM system doesn;t seem to matter on my 2001 - looks like they changed to an 85 in 01 so why pay for something I don't need
Old Jan 7, 2017 | 04:16 PM
Bluefire's Avatar
Bluefire
VaraRam fan here! After proper tuning your "butt-dyno" will approve.
Old Jan 7, 2017 | 06:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
100%
Old Jan 16, 2017 | 11:41 PM
Friscojim's Avatar
Friscojim
I just installed the AirRaid system - uses the stock MAF - easy install with a few tips I learned the hard way - don't tighten anything down even snug before fitting it back in - need the wiggle room to align it all properly - butt dyno gives it 2 thumbs up
To cold air intake
