installed column lock bypass, still get "remove key wait 10 seconds on DIC" Please help!
Guys,
I installed the C5 solutions column lock bypass on my 97. The steering wheels never locks anymore, but occasionally I will get the dreaded message " Pull key wait 10 seconds". If I don't pull the key, the car will stall when I try to drive it. And input on what I may have done or not done when I installed it? :(
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Re: still get "remove key wait 10 seconds on DIC" Please help! (1 slow 97)
It's possible to get that error code without anything to do with the column. It happens when the computer gets confused. I got it once when I pulled the key out and opened the door too rapidly. It just needs to reboot like your pc.
Re:still get "remove key wait 10 seconds on DIC" Please help! (1 slow 97)
Check for codes. You can always use the,"When all else fails", tactic of disconnecting the neg terminal of the battery for a few minutes. Hey, you never know..... :smash: :rolleyes: :D
