ADVISE ON INSTALLING SHOCKS
Old Sep 21, 2002 | 12:07 AM
batsallover's Avatar
batsallover
Default NEED ADVICE ON INSTALLING SHOCKS
Tomorrow I will be installing some Z06 shocks on the Vert. I checked out tech tips for some advice on saving some time.
For everyone that has changed shocks, are there any lessons learned your willing to share? Or is there already a tech tip write up available?
Thank you in advance for the help.
:cheers:
[Modified by batsallover, 4:36 AM 9/21/2002]
Update: Shocks are in and what a PITA the fronts were. The backs were easy though. The best way to get the job done is with lots of zip ties and to tighten them as you compress the shock. Use the same zip tie with the compressed new shock to easy install. Whew...time for a beer. :cheers:
[Modified by batsallover, 9:47 PM 9/22/2002]
Old Sep 21, 2002 | 12:59 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: NEED ADVICE ON INSTALLING SHOCKS (batsallover)
Plastic tie wraps come in real handy! :cheers:
Old Sep 21, 2002 | 06:17 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: NEED ADVICE ON INSTALLING SHOCKS (racer44)
sorry I didn't catch this earlier, how'd the install go :)
Old Sep 21, 2002 | 10:51 PM
Skyguy^^'s Avatar
Skyguy^^
I never could get good results with the tie wraps, instead, compressed them and just looped duct tape around them. :cheers:
Old Sep 21, 2002 | 11:21 PM
brewtoo's Avatar
brewtoo
Default Re: NEED ADVICE ON INSTALLING SHOCKS (Skyguy^^)
Use the come-along-like things from the hardware store. Fabric straps with hooks on the ends and a ratchet in the middle to compress the shocks.
Makes it EASY.
Not my idea...saw it somewhere on the internet...author called himself a genious. I agree!
:smash: :smash: :smash:
Old Sep 22, 2002 | 08:44 AM
batsallover
Default Re: NEED ADVICE ON INSTALLING SHOCKS (Mean Green 2000)
I am doing the install this morning. With all the rain lately, it was grass cutting time. Not only do I keep the Vette perfect, the house stays that way too. :lol:
Old Sep 22, 2002 | 05:48 PM
batsallover
ttt update
Old Sep 22, 2002 | 08:24 PM
ifeeltheneedforspeed's Avatar
Front shocks: disconnect the upper control arms ( four bolts, with spacers behind them that will drop our. Make sure you keep track of how many for each bolt). This makes removing and replacing the shocks easy. Forget this tie rap crap. Do it the way the pros do.
To ADVISE ON INSTALLING SHOCKS
