intake/water?
Old Sep 21, 2002 | 09:53 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default intake/water?
winter is comming that means a little rain here. which intakes do not suck up water?
or should i go with the K&N in a stock airbox.
is getting water in the intake a concern or am i just being overly stupid.
thanx in advance :rolleyes:
Old Sep 21, 2002 | 10:10 AM
vette.se's Avatar
vette.se
Default Re: intake/water? (devo)
Blackwing are the most common and have the highest performance of the non-cold air setups from what I've seen on the forum. It mounts above the radiator shroud and are as safe as the stock setup.
:cheers:
[Modified by seanr, 3:12 PM 9/21/2002]
Old Sep 21, 2002 | 10:51 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: intake/water? (seanr)
Dont drive through 6 " of water and you should be fine. In AZ it monsoons and flash floods. Just avoid large puddles
Old Sep 21, 2002 | 10:56 AM
Don&Kelly's Avatar
Don&Kelly
Your not being stupid - I believe the new VaraRam looks like the safest unit for your concern ... http://www.vararam.com/
Hope this helps ..
:cool: :cheers: :smash: :seeya
Old Sep 21, 2002 | 11:42 AM
edv2122's Avatar
edv2122
Default Re: intake/water? (Don&Kelly)
I have a Vortex but I fabricated a rain shield for it when i know it will rain and i must drive. Not hard to do. For me just a little piece of mind.
Old Sep 21, 2002 | 11:50 AM
Tom Steele's Avatar
Tom Steele
Default Re: intake/water? (edv2122)
I ran a vortex for 2 1/2 years and 49k miles as my only car - rain or shine.
I never had a problem with rain.
You have to TRY to scoop up water with it, just stay out of absurd puddles.
Old Sep 21, 2002 | 12:23 PM
TLewis4095's Avatar
TLewis4095
I have had the BMP rammer on for over a year and we are on the tail end of the FLA rainny season.....stay out of deep puddles and you will be fine. I have driven in monsoon downpours w/no problem....just don't drive through puddles!! :cheers:
To intake/water?
