HELP?! - ARH headers and O2 sensors
Old Jan 18, 2017 | 07:41 PM
Sam Handwich's Avatar
Sam Handwich
Default Solved - American Racing headers and O2 sensors
Replacing the FRONT O2 sensors in my C5. I have the 1 3/4" headers with cats.
Is it possible to do this without dropping the headers?
Thanks in advance for guidance, etc.
Old Jan 19, 2017 | 12:55 AM
Vett4MVZ's Avatar
Vett4MVZ
Just did mine with out issue. Took almost as long to jack up the car.
2000 coupe
Old Jan 19, 2017 | 09:12 AM
midnight01's Avatar
midnight01
As long as you used anti sieze on the threads of the sensors when you installed them it should be fine, if not they could be in there nice and tight causing a few screaming moments and scraped/bloody knuckles.
Old Jan 19, 2017 | 11:24 AM
Sam Handwich
I used anti-seize when the headers and sensors were installed for certain. Have the x-pipe down at the moment. Next step is to get the old sensors out.
Old Jan 19, 2017 | 04:57 PM
midnight01's Avatar
midnight01
should make for an easy job
Old Jan 19, 2017 | 06:19 PM
Sam Handwich
Easy is a relative term. Relative to who is doing the work.
Old Jan 20, 2017 | 08:18 PM
Sam Handwich
Thanks to all who offered help and advice, etc. In my case on the American Racing Headers I had to remove the mid-pipes to get at the front O2 sensors and install the new ones. And the headers sort of pinch the mid-pipes so tightly that even after the spring hangers were disconnected, and the mufflers unbolted from the rear section the pipes still would not drop.
Surprisingly, it took a bit of effort to dislodge the pipes from the headers.
Of course, to reconnect the mid-pipes and the headers I had to loosen the driver's side from the cylinder head.
Just wanted to put that out there in case someone else could be helped by a report on how it turned out.
To HELP?! - ARH headers and O2 sensors
