98 coupe blackwing question
Old Jan 20, 2017 | 11:38 AM
Jb11379's Avatar
Jb11379
Default 98 coupe blackwing question
What size coupler is needed for the Blackwing to connect the intake to the maf?
Is the stock one fine ? Bought an intake but doesn't have the coupler.
Thanks fellas!!
Old Jan 20, 2017 | 02:49 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
This comes up once in a while.
I had a response in a previous thread
https://www.corvetteforum.com/forums...post1589641806
Originally Posted by QCVette
I have a blackwing and used it on a '99.
The difference is in the rubber that fits it to the car. The early cars have the coupler that is stepped down to be smaller on the engine side. The later cars have a coupler that is the same size on both end so it is more or less just a rubber hose. The early cars have a 3.5" MAF (uses the stepped down coupler) and the later cars have a 4" MAF (uses the straight coupler).
Mine had both couplers with it when I got it used. I don't know if it originally came that way. If you have the early coupler, all you need is a section of the right size hose to connect it.
Good luck.
Old Jan 20, 2017 | 04:49 PM
Jb11379's Avatar
Jb11379
So I'd need a 3.5x 4 inch reducer?
Old Jan 20, 2017 | 09:58 PM
Jb11379's Avatar
Jb11379
​​​​​​​can anyone clear this up? Looking to order it tonight.
Old Jan 21, 2017 | 12:01 PM
Jb11379's Avatar
Jb11379
Anyone know?
Old Jan 21, 2017 | 12:30 PM
QCVette's Avatar
QCVette
I think that is correct.
To verify, put a scale across the two parts you are connecting.
Good luck.
Old Jan 23, 2017 | 09:51 PM
joe's98's Avatar
joe's98
St. Jude Donor '15, '17
I put one on my '98. I had to put a later model MAF on the car to make it work.
Old Jan 23, 2017 | 09:53 PM
Jb11379's Avatar
Jb11379
why weren't you able to just use a reducing coupler?
Old Jan 23, 2017 | 10:17 PM
joe's98's Avatar
joe's98
Have you found one? I didn't know where to look.
Old Jan 23, 2017 | 10:22 PM
joe's98's Avatar
joe's98
I also had to get an adaptor wire from racetronix to hook up to the new MAF. My car was scheduled for a tune and it was re calibrated for the larger MAF and intake.
To 98 coupe blackwing question
