Rack/steering sensor
Old Jan 22, 2017 | 08:44 AM
ottorexus's Avatar
ottorexus
6th Gear
Default Rack/steering sensor
I bought my first Corvette (2000) a couple of months ago and have done quite a bit of work to it. Pulled the motor and resealed everything,
replaced front left wheel bearing, new water pump, hazard button, and rack and pinion. After I did the rack I am getting the 1288 and 1281 codes (which I did not have before replacing the rack). I took it to a tire kingdom to have a wheel alignment done but am still getting the codes. Now I know tire kingdom is not the preferred vendor for corvette repairs but thought an alignment would OK. How can I check the steering sensor to confirm if it's bad or good? Any input would be greatly appreciated.
Love my Vette!!!!!
Old Jan 22, 2017 | 08:55 AM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Welcome to the forum. The members in the C5 Tech section should be able to help you with your problem.
Old Jan 22, 2017 | 09:42 AM
Moved this to C5 Tech.
To Rack/steering sensor
