Tunnel cover Cad drawing
Old Jan 22, 2017 | 11:54 AM
kirk tarrant's Avatar
kirk tarrant
Default Tunnel cover Cad drawing
Any one have one?
i searched and someone had one few years ago but i have no luck finding it
Old Jan 25, 2017 | 04:56 PM
The Chev's Avatar
The Chev
I was on the same search last year. I never ended up finding one.
I hope you do better than I did.
Old Jan 25, 2017 | 05:41 PM
Patches's Avatar
Patches
This would be an easy model/drawing to do. I'd whip one out if I had a reason to but I don't. What do you need it for?
Old Jan 25, 2017 | 08:55 PM
hatewhatownsyou's Avatar
hatewhatownsyou
The hard parts inspecting the tunnel plate to get the dimensions, do you have any of this patches?
I'd be interested to see what my aluminum supplier would charge me to water jet some
Old Jan 25, 2017 | 09:23 PM
Patches's Avatar
Patches
I have my aftermarket plate off and conveniently leaning against my work bench so it would be a simple matter of measuring and drawing it up. The question goes to incentive . . .
Seriously, not a big deal.
Old Jan 25, 2017 | 09:28 PM
kirk tarrant
I have access to cnc plazma table and free aluminum. Just want to make one for a project
Old Jan 25, 2017 | 09:46 PM
Patches's Avatar
Patches
I'll try to put aside some time this weekend and see if I can get you a drawing.
Old Jan 31, 2017 | 11:36 AM
Patches's Avatar
Patches
Old Jan 31, 2017 | 12:45 PM
hatewhatownsyou
Now you're just being a tease.
I should make one with triangulated ribbing so it actually does something
Old Jan 31, 2017 | 01:06 PM
The Chev's Avatar
The Chev
I was thinking that some well placed louvers, or even better NACA ducts would help airflow and the heat buildup in the tunnel.
Old Jan 31, 2017 | 01:24 PM
Patches's Avatar
Patches
I have the model done - I patterned it after my aftermarket unit that was on my C5 for several years so it fits correctly. I'm also doing a dimensioned drawing for documentation's sake.
I'd be careful with ducting louvers since this is meant to not only stiffen, but insulate from exhaust heat as well. If you louver it, you may be allowing heat from the H/X pipe to blow into the tunnel and heat up the cabin tunnel. I attached a sheet of adhesive heat shielding to my plate and it insulates very nicely.
Old Jan 31, 2017 | 02:02 PM
The Chev's Avatar
The Chev
You are correct on that. My issue with the insulation, I have some on mine BTW, is that insulation eventually allows heat transfer. And don't get me started on using aluminium as a device who's secondary objective is to insulate heat...... or again on the aftermarket solution for a steel plate is to use a material that is 1/3 the stiffness but make it 3 times as thick.
If you could create a low pressure area on the bottom side of the tunnel plate, you could then force air from the engine bay area through the tunnel and out the bottom of the plate, keeping fresh cool air in the tunnel.
........in theory at least.
Old Jan 31, 2017 | 02:21 PM
Patches's Avatar
Patches
Hmm . . . isn't that kind of airflow referred to as "lift"? Last thing I'd want under my C5 is hot air pushing downward at speed.
Anyway, I have the model and machine dwg. done. Where's the OP at - he asked for this to begin with.
Old Jan 31, 2017 | 02:30 PM
The Chev's Avatar
The Chev
Well, sort of.
Low pressure on the bottom of the tunnel plate would mean higher pressure on the top of the plate, and would then create a force in the downward direction. However, I seriously doubt that the airflow in that area is fast enough to actually create such a force........ it probably would not even create enough airflow to cool the tunnel area.
And yes, a lot of hot air in this thread. I bought a standard aftermarket plate and bolted it up. It is fun to go through the exercise though.
Old Jan 31, 2017 | 04:04 PM
kirk tarrant
i plan to burn the first one scrap sheet metal before i use aluminum.nice work
To Tunnel cover Cad drawing
