P0354
Old Jan 30, 2017 | 11:19 PM
lpina650's Avatar
lpina650
Default P0354
Can anyone help with this issue? I have changed the plug, wire, coil, and have gotten no luck.
Old Jan 30, 2017 | 11:39 PM
grantv's Avatar
grantv
Break in a wire in the harness running to the coil? Run a continuity test on the wiring? Dunno, just a thought out of the deep blue sky.
Old Jan 31, 2017 | 11:29 AM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Here is some info on the PCM hope it helps
PCM removal http://www.aacorvette.com/pdf/aa_c5_pcm_removal.pdf
PCM View Powertrain Control Module (PCM) Connector End Views
Table 1: PCM Connector C1 (BLU)
Table 2: PCM Connector C2 (RED)
Connector Part Information • PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin Wire Color Circuit No. Function
1 BLK/WHT 451 PCM Ground
2 LT GRN 1867 Crankshaft Position Sensor B+ Supply
3 PNK/BLK 1746 Injector 3 Control
4 LT GRN/BLK 1745 Injector 2 Control
5-6 -- -- Not Used
7 GRY 596 Engine Oil Pressure Sensor 5V Reference
8-10 -- -- Not Used
11 LT BLU 1876 Knock Sensor (KS) 2 Signal
12 DK BLU/WHT 1869 Crankshaft Position Sensor Signal
13 ORN/BLK 463 Requested Torque Signal
14 TAN 800 Throttle Actuator Control Serial Data
15 ORN/BLK 1061 Throttle Actuator Control Serial Data
16 -- -- Not Used
17 DK BLU 1225 Transmission Range Signal B
(Automatic Transmission Only)
18 RED 1226 Transmission Range Signal C
19 PNK 239 PCM Ignition Supply
20 ORN 340 PCM Battery Supply
21 YEL/BLK 1868 Crankshaft Position Sensor Ground
22 -- -- Not Used
23 GRY 720 Sensor Ground
24 -- -- Not Used
25 TAN 1671 HO2S Signal Low Bank 2 Sensor 2
26 TAN 1667 HO2S Signal Low Bank 2 Sensor 1
27 -- -- Not Used
28 TAN/WHT 1669 HO2S Signal Low Bank 1 Sensor 2
29 TAN/WHT 1653 HO2S Signal Low Bank 1 Sensor 1
30-31 -- -- Not Used
32 BLK/WHT 771 PRND A Input Signal
33 PPL 420 TCC Brake Switch
34 WHT 776 PRND P Input Signal
35 GRY 48 Clutch Switch
(Manual Transmission Only)
36 BLK 1744 Injector 1 Control
37 YEL/BLK 846 Injector 6 Control
38 PNK/WHT 1101 Powertrain Induced Chassis Pitch Signal (if so equipped)
39 -- -- Not Used
40 BLK/WHT 451 PCM Ground
41 -- -- Not Used
42 DK GRN 335 Engine Cooling Fan Relay 1 Control
43 RED/BLK 877 Injector 7 Control
44 LT BLU/BLK 844 Injector 4 Control
45 GRY 474 A/C Refrigerant Pressure Sensor 5V Reference
46 GRY 598 Fuel Tank Pressure Sensor 5V Reference
47 -- -- Not Used
48 GRY 416 MAP Sensor 5V Reference
49-50 -- -- Not Used
51 DK BLU 496 Knock Sensor (KS) 1 Signal
52 -- -- Not Used
53 ORN/BLK 1057 Transmission Temperature Sensor Ground
54 ORN/BLK 469 MAP Sensor Ground
55-56 -- -- Not Used
57 ORN 340 PCM Battery Supply
58 DK GRN 1049 Serial Data
59 -- -- Not Used
60 BLK 407 A/C Refrigerant Pressure Sensor Ground
61 PNK/BLK 632 Camshaft Position Sensor Ground
62 GRY 847 Extended Travel Brake Switch Signal
63 BLK 452 Engine Oil Pressure Sensor Ground
64 -- -- Not Used
65 PPL 1670 HO2S Signal High Bank 2 Sensor 2
66 PPL 1666 HO2S Signal High Bank 2 Sensor 1
67 -- -- Not Used
68 PPL/WHT 1668 HO2S Signal High Bank 1 Sensor 2
69 PPL/WHT 1665 HO2S Signal High Bank 1 Sensor 1
70 BRN 1174 Low Oil Level Switch
71 -- -- Not Used
72 YEL 772 PRND B Input Signal
73 BRN/WHT 633 Camshaft Position (CMP) Sensor Signal
74 YEL 410 Engine Coolant Temperature (ECT) Sensor Signal
75 -- -- Not Used
76 BLK/WHT 845 Injector 5 Control
77 DK BLU/WHT 878 Injector 8 Control
78 -- -- Not Used
79 GRY 587 2nd and 3rd Gear Block Out Solenoid Control (MM^)
79 WHT 687 3-2 Shift Solenoid Control (M30)
80 BRN 718 Engine Coolant Temperature (ECT) Sensor Ground
Connector Part Information • PCM Connector C2 Assembly 12191488
• TPA (RED) 12176410
2 BRN 418 TCC Control Solenoid
3 -- -- Not Used
4 PPL 421 AIR Solenoid Control
5 TAN/BLK 464 Torque Delivered
6 RED/BLK 1228 Transmission Fluid Pressure Control Solenoid High
7 -- -- Not Used
8 LT BLU/WHT 1229 Transmission Fluid Pressure Control Solenoid Low
9 DK GRN/WHT 465 Fuel Pump Relay Control
10 WHT 121 Engine Speed (Tach) Output Signal
11-13 -- -- Not Used
14 RED/BLK 380 A/C Refrigerant Pressure Sensor Signal
15 RED 225 Alternator L Terminal
16 -- -- Not Used
17 DK GRN/WHT 762 A/C Request Signal (C60 only)
18 DK GRN 59 A/C Status Signal
19 -- -- Not Used
20 PPL 401 Vehicle Speed Sensor (VSS) Reference Low
21 YEL 400 Vehicle Speed Sensor (VSS) Signal
22-24 -- -- Not Used
25 TAN 472 IAT Sensor Signal
26 PPL 2121 Ignition Control 1
27 RED 2127 Ignition Control 7
28 LT BLU/WHT 2126 Ignition Control 6
29 DK GRN/WHT 2124 Ignition Control 4
30 -- -- Not Used
31 YEL 492 MAF Sensor Signal
32 LT GRN 432 MAP Sensor Signal
33 DK BLU 473 Engine Cooling Fan Relay 2 and 3 Control
34 DK GRN/WHT 428 EVAP Canister Purge Valve Control
35 -- -- Not Used
36 BRN 436 AIR Pump Relay Control
37-38 -- -- Not Used
39 RED 631 Camshaft Position Sensor B+ Supply
41 -- -- Not Used
42 TAN/BLK 422 TCC Enable Circuit
43 DK GRN/WHT 459 A/C Clutch Relay Control
44 LT GRN 1652 Reverse Inhibit Solenoid Control
45 WHT 1310 EVAP Canister Vent Valve Control
46 BRN/WHT 419 Malfunction Indicator Lamp (MIL) Control
47 WHT 375 1 to 4 Up-shift Lamp Control (MM6)
47 YEL/BLK 1223 Transmission Shift Solenoid B (M30)
48 LT GRN 1222 Transmission Shift Solenoid A
49 -- -- Not Used
50 DK GRN/WHT 817 Vehicle Speed Output Circuit
51 YEL/BLK 1227 Transmission Temperature Sensor Signal
52 GRY 23 Alternator F Terminal
53 -- -- Not Used
54 DK BLU 1936 Fuel Level Sensor Signal
57 PPL 719 IAT Sensor Ground
58 TAN/WHT 331 Engine Oil Pressure Sensor Signal
59 -- -- Not Used
60 BRN 2129 Ignition Control Reference Low Bank 1
61 BRN/WHT 2130 Ignition Control Reference Low Bank 2
62 GRY 773 PRND C Input Signal
63 PNK 1224 Transmission Range Signal A
64 DK GRN 890 Fuel Tank Pressure Sensor Signal
65 -- -- Not Used
66 PPL/WHT 2128 Ignition Control 8
67 RED/WHT 2122 Ignition Control 2
68 DK GRN 2125 Ignition Control 5
69 LT BLU 2123 Ignition Control 3
70-72 -- -- Not Used
73 LT BLU 1937 Fuel Level Sensor Signal (Secondary)
74-80 -- -- Not Used
Old Nov 1, 2023 | 02:57 PM
douglasjre's Avatar
douglasjre
I got a p0354 on the CEL and I swapped coil pack four with coil pack 2, high voltage wire 4 with 6, and plug 4 with 8. code came up again 40miles later. Engine runs fine. Any common problems?
lpina650: did you figure it out? .
To P0354
