Motor mount question
Old Feb 4, 2017 | 05:35 PM
TheBandit18's Avatar
TheBandit18
Default Motor mount question
Just curious if the motor mount is bad will the motor sag? Had fluid on the passenger side under the motor mount and trying to put on a twin turbo kit and it's way off
Old Feb 4, 2017 | 09:38 PM
Rob 02's Avatar
Rob 02
They are like a shock. I would replace them. They are not expensive or hard to replace if you can lower the cradle and jack up the engine a little.
Old Feb 4, 2017 | 09:58 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes !!!
Old Feb 4, 2017 | 10:51 PM
TheBandit18
Ok I already took the factory ones out have solid motor mounts going in have to drill out the hole a little bit to the bracket to have the new bolts to fit
To Motor mount question
