C5 instant over rev
Old Feb 5, 2017 | 03:17 PM
docpokey's Avatar
docpokey
1st Gear
Default C5 instant over rev
for no reason my c5 will start over revving. Instant high rev where you have to break hard, go to neutral tap the gas and it stops. Just Started and is scary in traffic. What area control this thanks for the help.
Old Feb 5, 2017 | 07:12 PM
StingrayRebel's Avatar
StingrayRebel
is the check engine light on?... pull the codes and post what you find
Old Feb 5, 2017 | 07:55 PM
Rob 02's Avatar
Rob 02
That's scary.
Old Feb 6, 2017 | 10:09 AM
nsogiba's Avatar
nsogiba
You sure nothing is caught under/around the gas pedal? Floor mats can shift around during a panic stop. You could also be accidentally touching the gas with your foot under a panic stop.
Old Feb 6, 2017 | 10:28 AM
midnight01's Avatar
midnight01
throttle blades sticking? Maybe the TPS sensor? Check all your connectors at the throttle body and make sure they are not dirty or corroded.
To C5 instant over rev
