Replace Shroud
Old Sep 22, 2002 | 08:00 PM
NetJunkie's Avatar
NetJunkie
Default Replace Shroud
Can someone point me to a howto on replacing my radiator shroud? Mine was cut for a Vortex and I have a new one to put in its place.
Old Sep 22, 2002 | 08:25 PM
tito's Avatar
tito
Default Re: Replace Shroud (NetJunkie)
pretty straigh forward job...
get underneath the front and there are screws holding the bottom, on each side of the shroud about half way up.. there are retaining clips pop those out and i believe u can pick it right up and out.. its been a while.. so if i left anything out someone chime in.
Old Sep 22, 2002 | 09:03 PM
jschindler's Avatar
jschindler
Default Re: Replace Shroud (tito)
There are three wires "popped" into the shroud. Two on the right (one at the very bottom - the temperature probe), and the one for the MAF. It's not rocket science, but you do have to watch for things and be a little careful.
Old Sep 23, 2002 | 01:25 PM
CDHough's Avatar
CDHough
Cruise-In II Veteran
Default Re: Replace Shroud (jschindler)
Check out a vararam install instructions (their website). They have to remove the shroud and should have details and pics.
- Charley
Old Sep 23, 2002 | 04:25 PM
C5Noir's Avatar
C5Noir
What's the part # on the shroud?
Old Sep 23, 2002 | 09:25 PM
bojangles's Avatar
bojangles
Default Re: Replace Shroud (C5Noir)
The part # I have for the GM Vette shroud is 10254256. I'm going to order one and replace the shroud this winter.
Good luck.
To Replace Shroud
