[HELP] How do I ???
Old Sep 23, 2002 | 12:39 PM
Along4theRide's Avatar
Along4theRide
CF Old Timer
St. Jude Donor '14-'15-'16
Default [HELP] How do I ???
I suspect that the Halltech Magicbox I have installed may be causing me trouble during certain driving conditions and I'd like to remove it and try a couple of things without it to see if I am correct. However, after disconnecting it, the car runs like crap. I know I need to reset something and let the car relearn but I don't do this sort of thing oftern enough to know what to reset. Should I reset the PCM? Can someone help me with this?
Old Sep 24, 2002 | 03:17 AM
C5Cemo's Avatar
C5Cemo
Default Re: [HELP] How do I ??? (Along4theRide)
Yes, give a PCM reset a shot. Just disconnect the negative end of the battery for ~15 minutes, reattach the cable and go through the idle relearn process: 15 minutes idle without A/C on and 15 with it on.
Hope this helps :seeya
