Fuel Pump
Old Feb 17, 2017 | 08:22 AM
cobra3's Avatar
cobra3
Default Fuel Pump
Well it looks like it's fuel pump time for my 02 coupe so I wanted to ask everyone which pump are you using for the replacement. I don't want to replace the pumps and then have to do it again in a year because I put in a bad pump. I just wanted to get an idea of what brand pump people are putting back in to see if they are going with the oem or if there is a better replacement for it. Thanks for any advice, it's always appreciated.
Old Feb 17, 2017 | 10:48 AM
skip1980's Avatar
skip1980
I used the racetronix C5 pump with hotwire kit. FYI you don't have to purchase the hotwire kit. Pump was a direct bolt it.
Old Feb 17, 2017 | 06:30 PM
strand rider's Avatar
strand rider
while I am not qualified to give advice on this subject, I was told by three corvette restoration experts speaking to a group at a car museum :
Always by factory parts unless cost is a factor.
I don't always follow this advice, they were specifically restoration experts, and not into repair, but find it a useful touchstone for making buying decisions, as I don't really have the chops to know how one part might be superior to another, and have to follow the advice of others with higher skill levels when making buying decisions.
On the other hand, it's not top secret knowledge , anyone in the industry can build a good pump, and manufacturing always improves. OEM is designed as part of the overall system, so one knows the fit and function will hold no surprises. Kind of dull, in a world of advertising.
Old Feb 17, 2017 | 07:21 PM
skip1980's Avatar
skip1980
If you stick with a good brand like delco,denso,delphi, walbro (racetronix) you should be fine.
Old Feb 17, 2017 | 11:38 PM
StingrayRebel's Avatar
StingrayRebel
mods?... if stock or not a considerable amount of power over stock the walbro drop in kit from racetronix is a great setup... it's already assembled in a new bucket with thicker gauge wiring as well so it makes the swap easy, just switch over your fuel level sender and attach the feed hose and that's about it... I would highly suggest buying it with the hotwire harness as well, basically that is just a heavy gauge wire that pulls power for the pump directly from the alternator so you don't lose voltage through the factory wiring
To Fuel Pump
