Service lights on...
Old Feb 26, 2017 | 06:14 PM
Barry6547's Avatar
Barry6547
Default Service lights on...
Several days ago I drove my "new" 2001 C5, with 20,000 miles from Orlando, Florida to Tallahassee, Florida, without a problem. Last Friday I had the local Chevy dealership change out all fluids, replace radiator hoses, clamps and cap...and serpentine belt and ac belt. They also put in at no charge the skip shift eliminator (what a pleasant change!). So with all fluids changed including brake fluid, I had them check all the brake pads. This weekend it has been a pleasure driving my little beauty. When I started her up late this afternoon, the following messages kept coming up....
Service ABS, Service Traction System, Service Active Handling. So what's up? I am thinking it must be related to something they did when they had my car for a full day that needs to addressed. I am planning to take the car back to the dealership first thing in the morning. Any feedback would be greatly appreciated!! Thanks!
Old Feb 26, 2017 | 07:31 PM
Smoken1's Avatar
Smoken1
Have you pulled your codes using the DIC?
Old Feb 26, 2017 | 08:06 PM
Barry6547's Avatar
Barry6547
Originally Posted by 8VETTE7
There are several dozen codes that can cause the lights to illuminate. Without codes you can only guess..............
I'm a babe in the woods here...my first Corvette...and totally green on this stuff. Will try to have the dealership that serviced it last Friday take a look at it early tomorrow, if they will. I am not up to speed on codes, etc, obviously a lot to learn.
Old Feb 27, 2017 | 07:57 AM
sirdano's Avatar
sirdano
Suggest that you pull the code yourself and post them here BEFORE going to the dealer. If you have never pulled codes before here is how:
https://www.youtube.com/watch?v=SviRjIsy9G4
OR
http://www.c5forum.com/ayc/dtcdic.php
Post ALL the codes including the H or C or HC that follow each 5 character code. List the codes under the sensor they show under. ie 10 - PCM or 28 - tcs or 40 - BCM.
Codes you are particularly interested in are under 28 - TCS.
I would be armed with as much info on what is going on with your car as possible BEFORE having the Stealership touch it. JMHO as I do NOT trust Stealerships AT ALL.
Yeah could be something simple as a bad battery or fuse. I am sure dealer will not tell you that and charge you 1K to fix something not broke.
Old Feb 27, 2017 | 08:20 AM
Barry6547's Avatar
Barry6547
Nice kitty...looks like a little female. I have a few.
Old Feb 27, 2017 | 08:09 PM
sirdano's Avatar
sirdano
I actually got this photo online. Was to lazy to resize one of mine. I have a black male like that and he is a empathy cat. Anyone not feeling well/ depressed he hangs out with them. Smart too he can open doors.
Old Feb 27, 2017 | 08:16 PM
Barry6547's Avatar
Barry6547
They are amazing with their interpersonal skills...and can size a person up without much effort.
To Service lights on...
