Help explain some codes for me...
Old Sep 24, 2002 | 08:39 AM
luminary's Avatar
luminary
Default Help explain some codes for me...
Since I'm taking the car in for some warranty work, I decided to check out what codes have been thrown recently. If any of you guru's has a few minutes, can you explain what these codes actually mean?
B2252 Key Cylinder Switch Fault DCM-LEFT
B2282 Battery #1 Fault DCM-LEFT
B2284 Battery #2 Fault DCM-LEFT
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 Column Lock/Unlock Drive (8)
U1016 Loss Of Communication with PCM (No SOH Message Received -RFA
U1064 Loss Of Communication with DCM (No SOH Message Received -RFA
U1096 Loss Of Communication with IPC (No SOH Message Received -RFA
U1255 Serial Data Line Malfunction -RFA
The only problem the car is having right now the gear not engaging in reverse (posted a thread about it yesterday). I'm not too concerned about these since I haven't noticed anything else wrong, but for curiosities sake, I'd like to know what they mean.
Thanx!
