H & C Silly Question
Old Sep 24, 2002 | 01:14 PM
Number six's Avatar
Number six
Default H & C Silly Question
What is a Head?? And how does a different one help with more power.
I understand the Cam.
Old Sep 24, 2002 | 02:04 PM
pburant's Avatar
pburant
Default Re: H & C Silly Question (Number six)
A head is attached to the engine block atop a row of cylinders. The head contains the valves, valve springs, rocker arms, and also has ports or tunnels for the intake air and exhaust gas (yes, this means the intake and exhaust manifolds are attached to the heads). Heads can help make more power because they can contain larger valves and have larger ports, allowing more fuel in and gas out of the combustion chambers. Heads can also alter the compression ratio of the motor, because the head contains the top of the combustion chamber. Because the head is so critical with regards to how well the engine breathes, heads and cam should be carefully matched for optimum performance.
Old Sep 24, 2002 | 03:29 PM
Number six's Avatar
Number six
Default Re: H & C Silly Question (Buckmaster)
Thanks pburant.
I initially thought the Heads referred to the piston heads, but that didn't seem to make sense from the posts I was reading.
I assume they up the compression ratio by going down into the cyl and shortenning the distance between the piston head and the actual Head.
Old Sep 24, 2002 | 04:19 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
The head is milled usually .020 which in my case gave 11-1 CR with my H/c.
Jerry :cheers:
To H & C Silly Question
