Who knows the right numbers?
Old Mar 5, 2017 | 04:23 PM
txagg14's Avatar
txagg14
Default Who knows the right numbers?
Hello!
Is there anyone out there that can give a safe/healthy parameter for the "gauges" section of the DIC?
The numbers below are mine after a 20-30 minute drive at about 35 mph average.
As a new vette owner, I'm just curious if that seems about right
Oil Pressure __40___
Oil Temperature__210___
Coolant Temperature___200___
Trans Fluid Temp__198____
Old Mar 5, 2017 | 04:48 PM
stingray76l82's Avatar
stingray76l82
Coolant little hi but everything else looks normal. Somebody else will chime in with more knowledge. My coolant runs around 170-180
Old Mar 5, 2017 | 09:27 PM
aaronc7's Avatar
aaronc7
those look about perfect (normal), no need to worry
Old Mar 5, 2017 | 11:15 PM
foggy's Avatar
foggy
Lookin Good
Old Mar 6, 2017 | 12:29 PM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
What oil pressure you folks see when under moderate to heavy acceleration? Normal to see that 40 bump closer to 55-60?
To Who knows the right numbers?
