Control arms
Old Mar 5, 2017 | 06:26 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Control arms
I am getting a spare set of used front and rear control arms to replace the original ones. While I send the control arms to a machine shop to have the VBP bushings kits installed, should I tell them to install grease fittings on each of the control arm so I could grease the bushings later myself? Any pros and cons?
Old Mar 6, 2017 | 05:59 PM
leadfoot4's Avatar
leadfoot4
Personally, I think it would be a good idea, as long as they have them located properly, as in an orientation that allows you to access them with a grease gun.....
Old Mar 8, 2017 | 03:56 PM
Caveboy's Avatar
Caveboy
Anybody knows the exact locations to install the grease fittings?
Old Mar 14, 2017 | 10:55 PM
Caveboy's Avatar
Caveboy
Ttt
Old Mar 15, 2017 | 02:24 PM
SG Lou's Avatar
SG Lou
While your at it you might as well have new ball joints pressed in as well.
I purchased a full set of control arms and knuckles and installed bushings and ball joints. One less thing to worry about !
Old Mar 15, 2017 | 05:46 PM
leadfoot4's Avatar
leadfoot4
I don't know about an EXACT location, but I'd say "in the middle" fore and aft, and pointing up and somewhat outward, so you can get the grease gun on them.
Old Mar 15, 2017 | 09:19 PM
Rob 02's Avatar
Rob 02
About right there.
Old Mar 15, 2017 | 11:55 PM
Caveboy's Avatar
Caveboy
How much was labor to install all the control arms and ball joint bushings?
Old Mar 16, 2017 | 12:18 AM
Rob 02's Avatar
Rob 02
^That is not my picture but the only one I could find for you.
I do my own work and unfortunately don't take enough pictures.
Labor cost vary depending on the area.
A well seasoned shop that specializes in late model Vettes can install them pretty quick (less than 4-6 hrs) with fees of $75-$150/ hour.
No matter how good the shop is, if they don't have Vette experience they will be a little lost. It will take longer, cost more and they may not get it right.
I would rather go outside my area and rent a car to find a shop that does this kind of thing all the time.
To Control arms
