Headlights flickering
Old Mar 7, 2017 | 03:15 PM
bob22z06's Avatar
bob22z06
Default Headlights flickering
Ive noticed recently when I turn my headlights on the brightnes on them will be up and down about 30sec intervals and for me it almost feels like im switching form hi to low beams....the voltage shows around 14.5 consistent...can it be the bulbs or is it alternator?
Old Mar 8, 2017 | 02:07 PM
sstonebreaker's Avatar
sstonebreaker
Got any more details, like do they both dim at the same time? Does it happen at any speed or just at one speed? Anything you can think of might help diagnose the problem.
One thing our cars are infamous for is bad electrical grounds. Check the negative battery cable and make sure the connections are clean and tight at both ends of the cable. Also check any other ground straps you can locate on the car.
Other places to check are the wiring harness connectors. They can get corroded. Also check the underside of the fuse box.
Old Mar 8, 2017 | 10:52 PM
bob22z06's Avatar
bob22z06
Yes looks like both dim at the same time ..ill check the grounds on the battery and other places and sew if that will do
Old Mar 9, 2017 | 07:41 AM
runner140*'s Avatar
runner140*
Hey Bob...I has a similar problem some years ago....my fix was new bump stops. It was just that simple. When I flipped my bump stops, you could see they were very worn.
Old Mar 10, 2017 | 12:08 AM
bob22z06's Avatar
bob22z06
I checked the negative cable on the battery it was kinda loose so I re tighten it haven't drove it yet...weather about to turn bad here again...
What do u mean bump stops u talking about on the headlight?
Old Mar 10, 2017 | 07:57 AM
runner140*'s Avatar
runner140*
Each headlight has four "bump stops"...two to limit where it opens and two to limit where it closes...they get worn. Don't just turn them over, buy new ones, they are cheap.
To Headlights flickering
