Bird noise
Old Sep 24, 2002 | 06:00 PM
Fast98's Avatar
Fast98
Default Bird noise
When I start my 98 in the morning it sounds like I have a bird chirping under the hood. It will go away after it is warmed up. I believe it is the tensior, any ideas? :chevy
Old Sep 24, 2002 | 06:04 PM
CVCVCV's Avatar
CVCVCV
Default Re: Bird noise (Fast98)
Try some "STP Belt dressing" on the serpentine thingy... worked for me.
Perry.
Old Sep 24, 2002 | 06:11 PM
Fast98's Avatar
Fast98
Default Re: Bird noise (CVCVCV)
The belt was put on in july. Should not need that. :chevy
Old Sep 24, 2002 | 06:12 PM
Allgonoshow's Avatar
Allgonoshow
Its the tensioner pulley. Try a Squirt of WD40 inbetween the pulley and the sheild front and back. There is also a TSB on it and they have a replacement but not a warrenty deal.
Old Sep 24, 2002 | 06:32 PM
Fast98's Avatar
Fast98
Default Re: Bird noise (Allgonoshow)
Where can I find that tsb car is still under extented war.
Old Sep 24, 2002 | 06:39 PM
Topless's Avatar
Topless
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06-'07-'08
The TSB is 99-06-04-029a.
It calls for replacing the tensioner. Also, if you have an automatic, they will replace the alternator.
Old Sep 24, 2002 | 06:44 PM
alanh's Avatar
alanh
At about 60,000 miles, my bird quit chirping when I replaced my belts. :yesnod: and it had been chirping for a long time.
Old Sep 24, 2002 | 06:50 PM
Fast98's Avatar
Fast98
Default Re: Bird noise (alanh)
Thanks for the info big blue :chevy
Old Sep 24, 2002 | 08:53 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Fast98,
I also had the same problem - refer to TSB #99-06-01-007: Accessory Drive Squeak (Replace Idler Pulley).
It instructs the dealer to replace the idler pulley assembly on 1997 - 1999 Corvettes (and 1998-1999 Camaro & Firebird) with the LS1 engine. The new part, #12564401 (idler pulley assembly) has a thicker dust shield to prevent crushing of it. The bulletin states the original was crushed upon assembly, causing it to contact the bearing race and thus the squeak.
Ignore the advice on spraying various chemicals on the pulleys and belts. Follow the TSB instructions. The bulletin allows 0.3 hours for the dealer to replace. I had the pulley replaced per the bulletin and it eliminated the squeak.
Good luck.
Old Sep 25, 2002 | 05:33 PM
CVCVCV's Avatar
CVCVCV
Perry
Mine did it when still a BRAND NEW CAR so I should not have needed it either - but it WORKED! - and it's a criminally CHEAP solution - if it works for you - better than a bunch of replacement parts surely?
And if it doesn't work, darn it you have wasted $2.
Perry :smash:
Old Sep 25, 2002 | 07:31 PM
BLACK86's Avatar
BLACK86
From: Marblehead, Mass, 2003 Corvette Convertible Black/Black/Black
Its the belt tensioner pulley. Replace it now. I heard the brid noise and a week late the tensioner pulley went the belt came off and the car over heated. This all happend on a Sat. about 100 miles from my house. It was a big pain in the butt.
To Bird noise
