DIC: "Service Vehicle Soon"
Old Sep 24, 2002 | 07:34 PM
SvenOdin's Avatar
SvenOdin
Default DIC: "Service Vehicle Soon"
For the past month, I have been receiving the "Service Vehicle Soon" message on the DIC while driving. Never flashes when vehicle is started.
Clear the message and it repeats every 100 miles without fail.
Oil has been changed and DIC reset after oil change. Coolant flushed and serviced. NO codes to be found.
I have taken my 'vette to the local "stealership" and as of right now, they don't find anything wrong. :confused:
Service Rep. said they'll keep it until tomorrow as they want their main guy to check it out.
This is very frustrating :mad
Hopefully tomorrow they nail it down and resolve.
Old Sep 24, 2002 | 11:43 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: DIC: "Service Vehicle Soon" (SvenOdin)
Service Vehicle Soon applies to non drive train related items. The one time it showed up on my car was when I had the power steering rack replaced and the mechanic did not realize there was a correct orientation for the steering shaft. Once on the road the computer kept getting a reading showing the steering was at maximum deflection. First dealership that I went to was able to clear the code but did not realize the rack had been out of the car and could not determine why the code appeared. When I finally got back home the dealership that replaced the rack discovered the steering shaft was 360 degrees out and corrected the situation.
Bill
Old Sep 25, 2002 | 02:17 PM
SvenOdin's Avatar
SvenOdin
Dealer found nothing.
Next time message diplays on DIC I'll take it immediately to a second dealer. :mad :mad
Old Sep 25, 2002 | 02:34 PM
verskel's Avatar
verskel
That's bad, very bad......sounds like a computer error - :eek: ....good luck finding out the problem. Mine has the "airbag" symbol stick every once in a while & I still don't know why ! :confused: :smash: :confused:
Old Sep 25, 2002 | 07:34 PM
jeffh355's Avatar
jeffh355
Default Re: DIC: "Service Vehicle Soon" (verskel)
No codes on mine either. I have a habit now.... Start car, shut of traction control, clear DIC of service engine soon and traction control. Put in drive beat on car. :D
Old Sep 25, 2002 | 09:09 PM
Blue 02 C5's Avatar
Blue 02 C5
Are they telling you that there aren't any History codes?
Old Sep 25, 2002 | 10:28 PM
SvenOdin's Avatar
SvenOdin
Default Re: DIC: "Service Vehicle Soon" (Blue 02 C5)
That is correct. NO history codes. Of course, me like a dummy cleared the only code in history before bringing in to dealership. I told them what it was: 28 TCS C1281H (Steering Sensor Uncorrelated Malfunction).
Service guy told me that the sensor may need to be replaced, however, they would feel more comfortable waiting for message to display on DIC. This should occur in about 40 miles! (every 100 miles like clockwork).
I'll take the car out Friday and rack up the milage required to flash the message, then return to dealer.
One good point in all this, the dealer didn't charge me :D
Old Sep 25, 2002 | 11:38 PM
Bling Bling's Avatar
Bling Bling
I had the same thing. The message came on when I was driving about 70mph. The dealership said the message was pointing to an oxygen sensor. They tested the sensor and said it was fine. Never happened again.
Old Sep 26, 2002 | 06:41 AM
Joe's Eray's Avatar
Joe's Eray
Default Re: DIC: "Service Vehicle Soon" (Bill Dearborn)
Bill
Same exact thing happened to me with the when I had to have the steering rack removed.
Old Sep 26, 2002 | 11:38 AM
jerryv's Avatar
jerryv
Next time you get the message on the DIC .... don't clear it. WHILE DRIVING, get into diagnostics and check the codes.
To DIC: "Service Vehicle Soon"
