Battery
Old Mar 10, 2017 | 07:58 PM
Catman 1's Avatar
Catman 1
2nd Gear
Default Battery
Is the battery in a C5 Corvette under the hood?
Where is the hood release?
Old Mar 10, 2017 | 08:00 PM
Catman 1's Avatar
Catman 1
2nd Gear
Default Battery location & hood release
Please provide battery location & hood release location for C5 Corvette.
Old Mar 10, 2017 | 09:12 PM
coia96vette's Avatar
coia96vette
You are kidding right? If not, the hood release is by the drivers side knee and the battery is under the hood.
Old Mar 10, 2017 | 09:13 PM
SG Lou's Avatar
SG Lou
The same question, posted 2 minutes apart is not going to get you the answer any quicker...........Patience Grasshopper
Old Mar 10, 2017 | 10:12 PM
Dirty Dog's Avatar
Dirty Dog
Hood release is drivers side, under the dash, on the kick panel.
Battery is passenger side, right next to the fuse box.
The hood opens from the rear...
Old Mar 13, 2017 | 12:02 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Some owners have installed their batteries in the rear of the car. Most likely as stated above, it will be under the hood. There are two hood latches, one on each side of the hood located closer to the windshield than the headlights.
Old Mar 13, 2017 | 03:07 AM
strand rider's Avatar
strand rider
try to remember to grasp and pull open from the middle of the hood , to avoid it taking a sidewise set from flexing in one direction over many openings, if you lift from one side only.
And don't set your packages on the trunk lid while looking for your keys, same deal , the support structure is intentionally light weight and not designed for abuse. Plus, it identifies you as a , well, someone who is ok with warped panel fit .
Old Mar 13, 2017 | 07:16 AM
runner140*'s Avatar
runner140*
Get yourself an "owners manual" and read it. Either or both, get it in print form or get it digital but get one and read it.
Old Mar 13, 2017 | 08:14 AM
The suggestion to get an owner's manual and become familiar with it is a good one. Best of luck with your car and welcome to the forum.
Old Mar 13, 2017 | 08:40 AM
Macleod52's Avatar
Macleod52
For future reference nearly every car's hood release is on the driver's side under the dash.
To Battery
