service traction control
Old Mar 13, 2017 | 01:16 AM
bobby77302's Avatar
bobby77302
3rd Gear
Default service traction control
ok so I just replaced my transmission this weekend and after I got the car all put back together I bled the rear brakes and now my brake light on dash is on and the traction control light is on,they came on while I was bleeding brakes,tried to clear code but wont clear,any ideas
Old Mar 13, 2017 | 03:19 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the only sure way to get all the air out is the Auto Bleed with a Tech 2 !!
Old Mar 13, 2017 | 10:56 PM
Bill Dearborn's Avatar
Bill Dearborn
Brake light is probably due to air in the lines or in the BPMV. Did the brake lines drain while the cradle and brakes were out of the car? That could cause air to get into the BPMV which means a Tech 2 Automated Bleed or trying to get the air out of the BPMV by going somewhere and slamming on the brakes to get into the ABS. The air might float out of the BPMV if you can activate the ABS and if you are lucky then you can go home and do a normal bleed to get the air the rest of the way out of the system. Once you get the system thoroughly bled and have a hard brake pedal the brake light and tc problems should go away.
Do you happen to have a check engine light along with a traction control light? If so that may be driving the TC issue. Some engine problems mean the ECM can't control torque well enough to support the traction control function so the ECM sends a signal to the EBCM telling it the ECM can't do its job and the EBCM sets a code that tells the mechanic the problem isn't here it is in the ECM.
Bill
Old Mar 16, 2017 | 06:53 AM
Rob 02's Avatar
Rob 02
I had it happen when My 3rd brake light went out.
Is the wiring harness for the tail lights plugged in?
It is on the passenger side rear quarter.
To service traction control
