A different approach
Old Mar 13, 2017 | 08:05 PM
Z06Luke's Avatar
Z06Luke
Default A different approach
Intro:
I wanted to share the results of a recent project. I'm a major DIY'er; if I can build something myself and save a few hundred bucks I am all about it. I'm also always looking for a solution with a more efficient approach. I wish I had more and better photos, but when I get to working on something I'm usually focused on the task at hand and not on documenting my work.
Anyway, a little background on this project. I sheared off the 3/4 synchro keys in my factory T56 in my C5Z, and the gears had ground a few times due to the broken keys, so I knew that it would likely get expensive quickly if I were to try to rebuild my existing transmission. I got a good deal on a low miles T56, this one with MM6 gear ratios, not the M12 ratios that I had from the factory. I chose this because the gearing will be better for the future power gains that will be coming eventually, as well as because the fact that the taller 1st gear equals a stronger transmission. I tore down my old transmission and it was good that I opted for a new transmission, as the 5/6 cluster gear and main shaft had the splines completely fubar'd, and this wasn't even a problem that I knew about! Research shows that this is due to hard acceleration in 5th/6th gear. Needless to say, I will be doing my passing in 4th gear and below from now on!
The cluster gear:
The main shaft:
Analyzing Other's Failures:
I knew I needed billet synchro keys and a steel 3/4 shifter, but I needed to plan out what other items I would address while I was at it. Obviously I would like the a strong drivetrain, but I also was on a budget. I was considering a 30 spline main shaft and having my pinion EDM'd for the larger spline, but I wanted to do actual research rather than just relying on the word of others to determine what needed to be done to my car. I have a decent amount of experience analyzing mechanical failures, and every instance of a Corvette main shaft failure that I have seen does not look like a typical axial shear failure (where the shaft simply is not strong enough to hold up to the twisting forces placed on it, therefore it shears apart). Here are a few examples of axial shears (fortunately none of them are mine!):
When an axial sheer failure happens, it is a surprisingly clean break. Sometimes there's a small nipple that sticks out in the very center of the break, but it is otherwise a flat surface where the two sides twist apart from one another. When analyzing Corvette main shaft failures, all looked something like this:
This is clearly not an axial sheer failure. This looks to me like a failure caused by a lateral force (think of how a stick splinters when you break it over your knee). What would cause a lateral load to be placed on the shaft? I'll get to that momentarily.
Another item that always seems to accompany a main shaft failure in a Corvette transmission is damage to the pinion bearing carrier in the differential, breaking off its mounting ears (the damage seems to be most highly concentrated on the bottom and right hand side mounting ears when looking at it from the rear). Here's an example:
As you have seen in my previous photos, an axial shear is a very clean break! It is extremely unlikely that such a failure would destroy the pinion bearing carrier, especially given the fact that the sheared off shaft section (if acted upon by a force) could simply push further into the splined pinion socket, which would eliminate any contact between the two main shaft pieces. A simple axial shear wouldn't be likely to have enough interference of moving parts to cause such a failure.
So now the question is, what would cause the mounting ears on the pinion bearing carrier to break and cause a lateral load on the main shaft, breaking it as well? My theory is that the pinion gear attempts to climb down and away from the ring gear, which breaks the pinion bearing retainer mounting ears as well as snaps the main shaft due to misalignment. The main shaft failure is not the cause, it's just the symptom! When people upgrade to a 30-spline main shaft but do not end up addressing the pinion bearing carrier, they're simply using the stronger main shaft to prevent the pinion from walking too far into a state of misalignment, which is a band-aid fix to address an inadequate pinon mounting flange. It is not good to expect the main shaft to be the thing that holds the pinon in place; that is the job of the pinion bearing retainer.
I consulted 2 individuals that I know and asked for a 2nd and 3rd opinion; one is actually a mechanical engineer who specializes in gear box design, the other is a machinist with a mechanical engineering background who used to design heavy equipment. After showing them photos of failures, as well as laying out my theory of the pinion bearing retainer being the primary point of failure, they both agreed. I am not an engineer of any sort, so needless to say it felt good to be reaffirmed by sources who's specialty is in this area.
How to Address this:
There are a few methods that I found. One is to upgrade the pinion bearing retainer itself. There are a few examples of billet aluminum ones on the market, but $450 for a machined piece of aluminum seemed a bit steep and I knew that I could come up with a solution for a fraction of the price.
Billet Aluminum Pinion Bearing Retainer
Another option is to go with a C6Z pinion bearing retainer, but that requires a C6Z ring & pinion. Although it's a lot beefier, it's still cast aluminum, which is a compromise that I was not happy about.
C6Z Left, C5/C5Z/C6 Right
I realized that all I needed was to find a solution that would prevent all of the force from being focused solely on the cast aluminum mounting ears. I machined a plate that bolts over the top of the pinion mounting flange, and the back side is stepped to match the features of the pinion bearing retainer. If it looks a little corroded that's because it is. This was a test fitting prior to finishing the surface of it to clean steel. When I was doing this, documentation was not on my mind. Fortunately, I was able to locate low profile hex cap screws and design the reinforcement plate to fit under the factory differential cover with zero modifications!
The Reinforcement Plate:
Being that I cannot find an example of a 27-spline main shaft failing due to actual insufficient ability to handle axial load I'm not convinced that it is necessarily a major weak point. Is a 30-spline shaft better? Sure, but I don't think it's necessarily required for a street car of any power output, but I'm certainly not here to tell anybody not to buy one.
Other Work Done:
I wanted a transmission brace to help prevent case twisting, just as is available through a handful of vendors. I went ahead and built one myself. There's not much special to show with this, as I more or less copied the design of what is already available.
Another issue that the C5 has is that the differential is only mounted in the middle, which allows it to rock left to right, causing wheel hop. I also really wanted to build a Pfadt style brace to prevent this (it accomplishes this by giving the differential mount a wide base, on which it cannot rock), but I also wanted to find a way to use less material if possible. I figured out exactly how to do that, using adjustable length rods with heim joints to connect my home made transmission brace down to the subframe. I can say that the difference is night and day! The power delivery is INSTANT, which tells me that the drivetrain was moving a considerable amount before, and I had no idea how much it was moving!
Pfadt Brace:
Right Side Differential Brace:
Left Side Differential Brace:
Rear Shot Showing Both:
Old Mar 13, 2017 | 08:24 PM
KCK8766's Avatar
KCK8766
I'm impressed. Transmission and differential guts scare the crap outta me.
Old Mar 13, 2017 | 09:57 PM
Thanks for the good write-up.
Old Mar 14, 2017 | 01:29 AM
Rob 02's Avatar
Rob 02
That is pretty awesome.
Old Mar 14, 2017 | 05:56 AM
tungstenfoot's Avatar
tungstenfoot
I like this diff mount solution. Question on the phadt original mount, Maybe im not understanding that mounting scheme, does that brace mount to the diff case where you have circled? Or does it just rest on pads there?
Old Mar 14, 2017 | 10:55 AM
Z06Luke's Avatar
Z06Luke
I actually borrowed that pic from elsewhere, so I'm not the one who circled it. Yes, the Pfadt mount bolts to the differential there. If it didn't then there would be no benefit because the differential would just rock on top of it. It then uses the polyurethane feet to rest on the subframe, while the center bushing mount really just keeps it in place so that it doesn't have the tendency to walk around back there.
The Pfadt mount is actually a pretty great design. It gives the differential a wide base to prevent rocking (the further apart the supports are on anything the more resistance it will have to rolling). When the differential tries to rock, the polyurethane feet absorb the torque and prevent it from moving very far.
My design works on the same principal, but I was looking for a method that would integrate with the rest of the bracing that I had already built.
Old Mar 14, 2017 | 01:12 PM
The Chev's Avatar
The Chev
I really like your approach. It is all too easy to beef it up, but sometimes you have to take a step back and consider the failure and what needs to be improved, it may not be the part that breaks.
I've not torn down a Vette transmission / rear end group, but overall , I think you are moving in the right direction.
I can't help but wonder if the support brace on the pinion bearing retainer is even necessary with the differential mount that you created. If that keeps the diff from trying to walk, then the force is only rotational like it was designed.
I'm not suggesting that you remove it and go do burnouts, for science........ or am I?
I think I love the mount setup that you made because of the way it integrates everything into one structure. Do you feel like more vibration is making it through the chassis? The Pfadt mount seems like it still allows movement, so I don't love that, but then it probably absorbs vibration.......
Anywho, I like the new approach.
Old Mar 14, 2017 | 02:17 PM
Rob 02's Avatar
Rob 02
I thought about getting the Pfadt mount but it doesn't look like it can flex much from front to rear for when you have to drop the engine cradle.
Old Mar 14, 2017 | 04:19 PM
Z06Luke's Avatar
Z06Luke
I think it's still necessary. The differential brace keeps the entire unit from moving, but the problem with the pinion is internal to the differential. The pinion gear drives the ring gear, which is connected to the axles. If the axles have resistance to turning (which is always going to be the case due to the traction provided by the tires), then a force is going to be placed on the pinion in the opposite direction that it's trying to drive the ring. This turns into a fight for the path of least resistance - is the pinion going to turn the ring gear, or will it drive itself downward because the ring gear has too much resistance to turning? This reinforcement plate is designed to strengthen the pinion mounting so that turning the ring gear should always be the path of least resistance.
There is a slight amount of vibration that is transmitted that wasn't there before, but it's not too bad really. A C5Z isn't exactly a quiet, smooth, luxury car to begin with, so I think it falls well within the realm of acceptability. Speaking of vibration, I intend to turn my own Delrin control arm bushings in the near future. It will be interesting to
see what the result of vibration will be like with those.
Old Mar 14, 2017 | 04:22 PM
Z06Luke's Avatar
Z06Luke
That is probably true. I would just loosen/remove the two center mounting nuts that go through the rear subframe (the ones in the location of the factory diff mount) prior to dropping the engine cradle. From my results with my setup, I think the Pfadt mount is well worth it.
Old Mar 16, 2017 | 09:53 PM
Z06Luke's Avatar
Z06Luke
Today was the first day that I've really had a chance to take the car out and beat on it a bit. This could be all in my head, but I truly believe that the car handles better than it ever has before! The cornering seems significantly more stable! I think the drive train has a tendency to shift under hard cornering, providing uneven power output down to the ground. I passed this on nothing other then being a guy who knows his car.
Old Mar 16, 2017 | 10:56 PM
Rob 02's Avatar
Rob 02
It makes you wonder how much twisting and turning takes place back there.
It would be interesting to stick a Go-Pro cam under the car to see.
Old Mar 16, 2017 | 10:58 PM
Z06Luke's Avatar
Z06Luke
That would be WAY interesting! If I only had a go pro I'd consider loosening my diff braces and going for a spin!
Old Mar 16, 2017 | 11:32 PM
Rob 02's Avatar
Rob 02
I have been trying to justify getting one. I guess it would make a good dash cam when you are not diagnosing suspension problems.
I saw a Fast And Loud episode where the camera view was from under the car and it gave me the idea.
Old Mar 17, 2017 | 09:07 AM
nsogiba's Avatar
nsogiba
Really cool setup, I like your solution to the trans mount. When I dropped my 2000 FRC drivetrain I was SHOCKED at how much movement was allowed between the diff and cradle. I thought for sure the mount had ripped, but it looked new.
Old Mar 18, 2017 | 08:20 PM
Sam Handwich's Avatar
Sam Handwich
bump for later.
I will learn a lot reading this
To A different approach
