Rear tie rod end length
I need some help here... I decided to get into my car and replace all 4 tie rod ends. I purchased two front tie rod ends, Item number 575001, and two rear tie rod ends Item number 585035
Front 575001
Rear 585035
The front's went on great, no issue.
But the rears! I'm supremely confused!
I knew the rear tie rod ends are supposed to be longer... I expected this.
But when I pulled the existing rear tie rods off the car they were SHORT! Shorter than my new rear tie rods.
Additionally the threading on the new tie rod end is much longer than the old tie rod ends. The threading is so much longer now the castle nut is is no where near the cotter pin! What the heck!?
Here is the tie rods next to each other, old on left new on right (if it's not obvious
And here is the cotter pin sitting well above the castle nut
Do I need to be worried about this? Is it fine?
I bent the cotter pin such that it would get into one of the castle nut notches. The way you show it it can loosen up quite a bit before stopping the castle nut from getting looser.
If your worried about it pay 2x the money and get the factory part
