z06 manual diff work with 1998 auto?
Old Mar 23, 2017 | 11:24 PM
harrykerry's Avatar
harrykerry
Default z06 manual diff work with 1998 auto?
I found a Z06 manual differential. Id like to put in a 1998 c5 auto, is there any difference in the differentials?
Old Mar 24, 2017 | 01:24 AM
PDQC5's Avatar
PDQC5
Yes , very popular upgrade
Old Mar 24, 2017 | 01:32 AM
harrykerry's Avatar
harrykerry
Default Thanks
thanks alot, Im ready to pay for a very low mi 3.42 diff, but it said it was manual, and I was nervous..Thanks alot, Ill let you know how it goes. Im in the hills, and the 2.73s just lug.. Im sure Ill like the 3.42s on these mountain roads...
Old Mar 24, 2017 | 08:25 AM
feeder82's Avatar
feeder82
bolts right in, keep in mind you will need a tune to set shift points
Old Mar 24, 2017 | 10:42 AM
harrykerry's Avatar
harrykerry
Thanks, Im going to a driveline shop this moring and see if they can reprogram, or maybe buy a handheld tuner and do it in their parking lot after its installed, or could I drive it somewhere for a tune?
Old Mar 24, 2017 | 04:38 PM
harrykerry's Avatar
harrykerry
Default Thanks
Thanks, paid for it today, should have her in a week or so....
Old Mar 24, 2017 | 10:17 PM
Should be a nice improvement in performance.
Old Mar 25, 2017 | 03:15 PM
Patches's Avatar
Patches
You'll need to transfer the A4 diff adapter plate from the old to the new diff.
Here's the adapter plate I transferred from my 2.73 diff to my 3.42 diff a few years ago. It's held in essentially by the O-ring so it's not pressed in with a lot of force. You should replace the large, outer O-ring and shaft seal while it's out.
Old Mar 26, 2017 | 01:22 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I did this exact same mod on my 98 auto trans car---You will need a "shift point correction" in your tune when changing gears--However you do not need a speedo correction when changing gear ratios
Finally I was quite disappointed after this mod--Thining the lower gear ratio would help my 1/4 mile times and my 0-60 times----The gains were almost nothing --less than 1 tenth in the 1/4-----I was far more happy by adding a "stall converter" to my trans----This mod made my car almost 1/2 second quicker in the 1/4 mile and 2-3 tenths faster in the 0-60 times----- I ended up doing both mods but if I were to do it over again I would do the stall converter only----I would reccomend nothing smaller than a 3000 stall and trust me you will love it and your car will become a beast !!! ( my heads and cam 98 would run in the low 12's with the 3000 stall---)
Old Apr 1, 2017 | 01:16 AM
harrykerry's Avatar
harrykerry
Default Dissapointed?
Im confused, I was hoping changing the rear end to 3.42 would be a good mod for my car, especially in the hills that I live.
Old Apr 1, 2017 | 09:27 AM
Rob Petyo's Avatar
Rob Petyo
now have them upgraded to 3.73's and put in a 4K yank and feel the difference, you'll love the 3.42 but I think you should go with a higher stall, maybe 3,600. Don't fear the gear they say
I ran the 3.73's and 4K yank until I wore it out then went with a 3,800 PA series. Car runs low tens NA
Old Apr 1, 2017 | 11:38 AM
harrykerry's Avatar
harrykerry
Default Shift Point Correction?
Can I use a diablo Preditor to change the shift points? Or any other handheld tuner that you would recommend? There are no local tuners in my northern ca area..
Old Apr 1, 2017 | 08:27 PM
harrykerry's Avatar
harrykerry
Do you know where I can buy the o rings? I tried GMparts, and they show it obsulete?
Old Apr 2, 2017 | 10:43 AM
Patches's Avatar
Patches
This is the large seal plate O-ring at Cultrag.
http://www.cultragfactoryparts.com/oe-gm/12369456
Old Apr 2, 2017 | 01:03 PM
harrykerry's Avatar
harrykerry
Wow, thank you so much!
To z06 manual diff work with 1998 auto?
