LCM5 installed, Service Column Lock Error
Old Mar 24, 2017 | 10:56 PM
Josh67's Avatar
Josh67
Default LCM5 installed, Service Column Lock Error
I bought my 2002 Z06 about 6 months ago and installed a LCM5 as preventative maintenance shortly after. Everything was fine for about 5 months. Last Saturday I parked it in the garage with the dome lights on and killed the battery. After jump starting the car I got the Service Column Lock error. I drove it for a few hours then put it in the garage and put the battery charger on it just in case. I pulled fuse 25 & 29 let it sit for half an hour and started the car up. No Column Lock error. I didn't drive it anywhere. The battery is an almost new Optima. Now when I went back out and started it the error is back. Any guess on what's going on? Did my LCM5 die?
Old Mar 24, 2017 | 11:11 PM
gpruitt54's Avatar
gpruitt54
I had the same thing happen. I have been installing a new radio in the car. As a result, I have installed and pulled the battery several times. Now I also am seeing the Service Column lock. I also have installed the LMC5 device as you did. I have not driven the car since the Column lock message. Should I now drive the car?
Old Mar 26, 2017 | 06:04 PM
gpruitt54's Avatar
gpruitt54
Originally Posted by 8VETTE7
I suggest that you each contact Compliance Parts and discuss the problem with them.
Here is a link to their contact page from their web site:
http://www.complianceparts.com/contactus.html
They are in Calif so take that into consideration if you call............ They are often around on weekends so don't let that hinder you in contacting them.
Please post back your results....
Thanks, I will do just that.
Old Mar 26, 2017 | 09:39 PM
gpruitt54's Avatar
gpruitt54
I have not tried pulling fuses 25 and 29. Guess I will try it and see of that works.
Old Mar 26, 2017 | 09:42 PM
Drewstein's Avatar
Drewstein
Either of you do the brown wire mod? My money is you need to do that too.
Old Mar 26, 2017 | 10:18 PM
gpruitt54's Avatar
gpruitt54
Did the install last year, cannot recall if I did the brown wire mod. I just removed fuses 25 & 29. will reinstall the fuses and see what gives. Brown wire mod... Humm... Likely not. I lift an email with Customer Support and will call tomorrow.
Old Mar 26, 2017 | 11:49 PM
gpruitt54's Avatar
gpruitt54
Pulled fuses 25 & 29. Left the fuses un-connected for about 30min. Reinstalled the fuses and all is well. No more Column Lock error. Will connect with tech support for more information.
Old Mar 27, 2017 | 03:43 PM
gpruitt54's Avatar
gpruitt54
Hmmmmmm,
Sounds like the BCM was very confused from the battery disconnects/connects and pulling the fuses caused it to "reboot" so to speak. Would like to hear what Compliance (Richard) has to say on this...... LMC5 can't fix the BCM when it gets hosed up...............
Talked with Richard this afternoon. As expected, it was the low battery voltage that caused the error. I pulled the fuses. Richard said that I could have simply pulled the negative battery terminal for a few minutes to reset the BMC. All is well and I have driven the car with no issue at all.
Old Mar 28, 2017 | 12:02 AM
Drewstein's Avatar
Drewstein
It's 5 seconds to pull the passenger kick panel and see if the brown wire on the LMC5 is cut or not. If it's not cut then you haven't done it yet.
Old Mar 28, 2017 | 12:32 PM
gpruitt54's Avatar
gpruitt54
I should pull the instructions on the brown wire mod. But, is there no jumpering required for the mod?
Old Mar 28, 2017 | 11:21 PM
Drewstein's Avatar
Drewstein
Nope. The mod involves replacing another wire just like the first two wires and then cutting a brown wire on the LMC5. If the brown wire is intact on the unit then the mod isn't complete.
To LCM5 installed, Service Column Lock Error
