Loud Squealing C5 z06
Old 03-26-2017, 08:51 PM
ssinani
ssinani's Avatar
Default Loud Squealing C5 z06
Hi guys, My 01 z06 started squealing from under the hood. I replaced the belt and it fixed it for several days and came back. I replaced the tensioner pulley and again it was fixed for a bit and came back again. Any ideas what might causing this as I cant pin point it.
Thanks in advance,
Kind Regards,
Sarmen Sinani
Old 03-26-2017, 09:22 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
With the engine running look at the balancer pulley on the front of the crankshaft. If you see a little wobble there's your problem. It's killing the belt.
Another possible is the alternator bearings are going out.
Old 03-26-2017, 09:25 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Oh.... any coolant get in the belts? It can get in the grooves of the pulley and even with a new belt it can make it squeal too. You remove the belt, degreaser on the pullies, wipe down in the groves... should settle that if its coolant.
Old 03-28-2017, 02:24 PM
old stingray
old stingray's Avatar
I had the same problem,ended up replacing both belt tensioners.
Old 03-28-2017, 02:38 PM
unlvrebel
unlvrebel's Avatar
Also check if the squeal in relation to HVAC being on. Could be the AC pulley.
To Loud Squealing C5 z06
Quick Reply: Loud Squealing C5 z06
