HELP! Problem lowering!
Old Sep 25, 2002 | 07:24 PM
FRC21's Avatar
FRC21
Default HELP! Problem lowering!
I printed out the instructions, and have followed them perfectly. But, the damn lower A arm wont drop! :cry :mad Whats going on?
Old Sep 25, 2002 | 07:40 PM
FRC21's Avatar
FRC21
Default Re: HELP! Problem lowering! (FRC21)
Any thoughts guys? The car is apart. :(
Old Sep 25, 2002 | 07:57 PM
NassyVette's Avatar
NassyVette
Front or back? More info please.
Old Sep 25, 2002 | 07:59 PM
FRC21's Avatar
FRC21
Default Re: HELP! Problem lowering! (NassyVette)
Front, when I lower the jack everything stays together. I have the sway bar bolt undone and out of the way, and the lower a arm nut is off. I've tried to pry it down with no luck.
Old Sep 25, 2002 | 08:48 PM
FRC21's Avatar
FRC21
Still no luck. Im just gonna put it back together.
Old Sep 25, 2002 | 08:52 PM
Patches's Avatar
Patches
Some other guys with the same problem have unbolted the upper A-arm to accomplish this instead.
Old Sep 25, 2002 | 08:55 PM
FRC21's Avatar
FRC21
Default Re: HELP! Problem lowering! (Patches)
hmmmmmm, what the hell. I'll try it!
Old Sep 25, 2002 | 09:21 PM
thegypsie's Avatar
thegypsie
That is what I had to do. There is a similar thread from a week or 2 ago where I went in a little more detail. Do a search if you need additional info.
Old Sep 25, 2002 | 09:23 PM
kwik8racr's Avatar
kwik8racr
Default Re: HELP! Problem lowering! (thegypsie)
That's the way to do it, pull the 4 bolts out on the upper a-arm, and let it all fall back, then it's real simple! :yesnod:
Old Sep 26, 2002 | 04:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Don't forget the shock, I believe it takes a 13 mm nut and bolt
Old Sep 26, 2002 | 08:51 AM
FRC21's Avatar
FRC21
Default Re: HELP! Problem lowering! (n6607)
I had the shock un-bolted also.
I got everything off by taking out the upper a-arm bolts. It was a job, but everything is back together.
Thanks for the help guys! :cheers:
Old Sep 26, 2002 | 09:46 AM
Patches's Avatar
Patches
C:cool::cool:L! :cheers:
Don't forget to post pics of that bad boy! :yesnod:
Old Sep 26, 2002 | 05:19 PM
C5GARY's Avatar
C5GARY
All you need to do is take another jack and a piece of wood and jack up the leaf spring a little bit (be careful to get just the wood touching the spring).. THEN, just reach in there and turn the adjuster by the rubber on the bottom (or if its dirty and stuck, use a wrench on the top). DO NOT un-bolt ANYTHING!! After you un-bolt and re-bolt, you probably better get the alignment checked. It should be about a 15minute job, including washing your hands .
Gary :)
To HELP! Problem lowering!
