Pfadt poly bushings - fitment issue
Old May 12, 2018 | 12:15 PM
rrankins's Avatar
rrankins
Originally Posted by apex26
Wondering if you could put a bolt and washers through the bushing to compress it enough to get started over the mount, then remove the bolt and washers. There were no such problems with the Prothane. I scored a circle on the inside of each bushing with a dremel, then added a grease zerk in case they start to squeak, some guys have taken them apart just to grease them, didn't want to go there. The difference in feel and handling is amazing, well worth the PIA the job is.
Yeah, that's the method I'm going to try. I put a C-clamp on and it appeared the compressed enough to get them in, but a bolt will be easier way to do it. Unfortunately, I need to run out to hardware store to get a bolt. None of the spare bolts I have laying around are big enough.
Old May 15, 2018 | 04:38 PM
rrankins's Avatar
rrankins
As a follow up, the bolt method worked perfectly.
I compressed the bushing as much as I could, and then tapped the end of the control in with a dead blow hammer to get them started until it hit the bolt. There was enough clearance that the tops of the flanges were inside the proper location in the cradle.
I then put a jack under the control arm end, removed the bolt, and then used the jack to press the control arm the rest of the way into the cradle where I installed the proper bolt and camber plates.
So, after 2 weekends and a few hours on the week nights after work, I have it all back together. Now to get an alignment done.
Thanks everyone for the advice.
Old May 15, 2018 | 04:50 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Old May 15, 2018 | 05:30 PM
mykream's Avatar
mykream
I installed my rear upper and lowers a couple months ago. I used a bolt, washer on each end, and a nut and compressed it. Went right in. Just need to be smarter than the bushing
Old May 15, 2018 | 05:46 PM
apex26's Avatar
apex26
Let us know how you like the upgrade. Despite what a PIA it was, I'd do it again.
Old May 15, 2018 | 05:56 PM
rrankins's Avatar
rrankins
Will do - I'm heading to Lime Rock with it Monday.
