Ls1 oil leak
Old Mar 31, 2017 | 02:15 PM
johnfin's Avatar
johnfin
Default Ls1 oil leak
I used the uv dye. Not coming from slot in bell housing. Its dripping from the starter bolt up high on engine. No oil from heads up. Drips down the joint between engine and belhousing. Some of the cross main bolts look wet but this starter area is dripping bad. Any ideas?
Old Mar 31, 2017 | 03:38 PM
evolmotorsprt's Avatar
evolmotorsprt
You might want to take a look at the oil pressure sending unit. It's not on that side of the motor but the oil may be making its way over there.
Old Apr 1, 2017 | 11:27 AM
johnfin's Avatar
johnfin
Its below the heads..i used a scope to look at cam and oil sending units.
Old Apr 1, 2017 | 11:22 PM
johnfin's Avatar
johnfin
Took starter out and flywheel is bone dry. So if it was the crank plug, rear main or cover, wouldnt it be wet in there? And if the rear cover leaked i would think it would go into the bellhousing and out the slot which its not. Unfortunatly i think i need to pull the transmission.
To Ls1 oil leak
