Question about C5 door speakers
I proceeded to change the tweeters in the right and left doors. Everything works and sounds good, but no driver side woofer.
Questions:
1. if the tweeter in the driver side doors are working, does that mean that the Bose amp in the drivers side door is working properly?
2. The C5 woofer looks completely different from anything I have seen, can the speaker itself be removed and install. Or, does the complete unit need to be replaced?
3. How can I test to confirm that the issue is with the Bose door speaker amp or the woofer itself?
Questions:
The amp for the 3.5" speakers in the doors and the rear speakers is in the radio head unit itself. The 8" woofers in the doors have their own amp in the housing that the 3.5" speaker mounts to. There is a signal processor under the dash above the gas pedal that splits the output from the radio to the various amp modules.
So, there is a relay and fuse in the passenger foot well fuse box for the amps for the woofers. I do not recall if there are 1 or 2 fuses for these.
A couple of things to check:
1. The wire harness going through the accordion tube checking for damaged or broken wiring.
2. Fuse #28 and relay #45, it looks like these are common for both doors.
The woofer can be replaced however, it can only be replaced with another woofer from a C5. May people sell the complete speaker pod.
You can swap the speaker pod between the doors, or just buy another working speaker pod. They are not side specific.
Now since you are using an aftermarket radio, did you get the correct interface adapter to maintain the functionality of the Bose system. IIRC the most common one is the PAC AOEM-VET1. This keeps all the Bose components working with an aftermarket radio.
Gary
From my experience, the woofer is probably bad.
Gary
Everything works except the left door woofer.
I will look to the fuse box in the passenger foot well.
