ROEM-VET1 install question
Still using factory wiring. If the rears are low volume then bypass ROEM-VET1 and hook rear speakers right to radio.
So second question would be should this be done for tweeters in doors or do they get filtered by subs crossover?
If they are filter by corssover why does adjust pots on VET1 change the volume to them?
First will ohm each rear wire from radio to stock wiring.
If I can will try and open VET1.
If I cant open and do find resistance will splice radio to rear stock wires.
Figure will do this to adjust the new tweeters in door found this procedure
Here is what needs to be done -
1. Hook up the PAC ROEM VET1 - DO NOT use the red stripe wires!!
2. Turn on your new radio, adjust treble and bass to about 3/4 from their highest level
3. Put the fader to the Front Right Speaker ONLY.
4. Adjust the FR screw Counter clockwise until the high Frequency kicks in. If you keep going this way you will loose all the bass as well. Use this adjustment to set the optimal sound balance.
5. Do the same steps 3 & 4 above for the left front speaker.
6. The PAC ROEM VET1 did not have to be adjusted for the rear speakers.
