Rear sway bar adjustment
I just want to know if there is any special way to make the adjustment. Can I just loosen the bolt, put it in the other hole and tighten it back up? Or do I need to get the wheels off the ground or anything like that?
Thank you!
The rear sway bar corrects how straight your leaves a corner or from a hard launch--If the rear swings to the LEFT you shorten the adjuster---If it swings to the RIGHT you lengthen the adjuster
The front sway bar adjustment is more about the rate of your sway bar and not the adjustment----typically you would start with a neutral setting--with no preload---You make the sway bar rate either softer or stiffer with a differently rated bar---
You make get other opinions on this but this is how we set up a car used for road racing or circle track racing
