Horn Replacement
Old Apr 11, 2017 | 04:29 PM
Tony P.'s Avatar
Tony P.
Default Horn Replacement
Anyone know how to change out the horn? I can't even find it. Not the steering wheel membrane, but the horn itself.
Old Apr 12, 2017 | 12:19 AM
If I recall correctly, the horns (2) are located at the very front of the car on the passenger side directly underneath the headlights and frame rail. To access them, there is an access panel under the front fascia (has the passenger side air dam attached) that you can remove and the horns are directly above.
Old Apr 12, 2017 | 08:08 AM
Tony P.'s Avatar
Tony P.
Default Horn Location
Thanks Vetteman Jack. This is very helpful.:
Old Apr 12, 2017 | 08:09 AM
Tony P.'s Avatar
Tony P.
Thanks Vetteman Jack, this was very helpful!
To Horn Replacement
