2003 ignition bezel black plastic
It's a matter of three T-15 screws, four 10mm nuts, and like four electrical connectors.
Follow these instructions up to Step 3g: http://www.vetteessentials.com/instr...zel_howto.html
You still have to remove the radio bezel. To remove the ignition bezel, grip firmly and pull straight off. IIRC the bezel attachment point is around the 1:00 position and it holds on pretty tight.
