BCM and Alarm
Old May 1, 2017 | 03:18 PM
Hvymtlc5's Avatar
Hvymtlc5
Default BCM and Alarm
Took the BCM out ot check for water damage from the midwest rains this week since car showed a bunch of error messages after the rain and would not start (no corrosion or water found). We did find a bad battery. I re-installed the BCM and new battery. When I opened the driver door (was unlocked) the alarm went off and I couldnt cancel with the FOB. Had to disconnect the battery?
Now when I hook the battery up alarm goes off all the time
Old May 1, 2017 | 03:37 PM
v6turbo87's Avatar
v6turbo87
Try putting your key in the lock and see if it cancels the alarm???
Old May 1, 2017 | 03:54 PM
Smoken1's Avatar
Smoken1
Try unlocking it with the key in the drivers door?
Old May 2, 2017 | 09:31 AM
Gordy M's Avatar
Gordy M
You should also try to reset your Key fob to the car. I cannot remember the procedure but it is in your owners manual.
To BCM and Alarm
