Brake Pads
Old May 2, 2017 | 12:33 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Brake Pads
Hey guys.
I'm currently running centric rotors and stop tech pads. I forget which pads at the moment, but they are a street type, not track specific. Maybe like an street/track combo. I'll look it up tonight.
What I'm thinking though... Is that I'm putting brand new CCW sp500s on this week and I want to look at limiting or eliminating brake dust. What's a good option for aggressive Street?
Old May 2, 2017 | 03:34 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
If you want a quality low dust pad I would recommend the Carbotech 1521 100% made in the USA. Non-corrosive dust will not harm your wheels or paint.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
You can order by calling me at 216-780-8825 or direct at http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$.
Part numbers
F: CT731 $148 R: CT732 $128
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old May 3, 2017 | 11:48 AM
cbell3186's Avatar
cbell3186
Have the same centric and stoptech setup. DUUUSSSTYY!
Old May 4, 2017 | 12:46 PM
Tusc's Avatar
Tusc
But good power for the price! =)
Also looking at the C6Z brake swap... So maybe I'll just pull that trigger.
Old May 4, 2017 | 06:34 PM
Carbotech Adam
Supporting Vendor
If going C6Z swap your pads will be 2-3 times the money for not that much more improvement.
Old May 7, 2017 | 09:28 AM
Tusc's Avatar
Tusc
C6Z brakes at 150+ to zero would be only marginally more effective than factory base C5 setup?
Old May 7, 2017 | 12:03 PM
Carbotech Adam
Supporting Vendor
Well yes they will be better at those speeds they are 6 and 4 piston calipers but the cost of the pads is $$$ Your money will be better spent on a real BBK Wilwood or Stoptech or what ever.. Especially if your looking at those speeds on the street..
Old May 7, 2017 | 09:21 PM
racebum's Avatar
racebum
Hey guys.
are you running blanks? practically every pad dusts with slotted rotors. that's a very low dust pad you have already if it's a stoptech street
Old May 8, 2017 | 01:53 AM
Tusc's Avatar
Tusc
That is a solid point. $430 to $500 for some pads depending on manufacturer. Dang.
So then what am I missing when KNS shows stoptech street pads for the Z ringing in at $60 for fronts. Would that then be $180 for 3 pairs of padlets for the fronts and $120 for two pair out back?
Old May 8, 2017 | 04:41 PM
racebum's Avatar
racebum
? unless you have a 6x6 you only need front and rear which are like 110 combined on amazon
309.07320 is the rear and 42.95 with free shipping
309.07310 is the front and 70.08 with free shipping
Old May 9, 2017 | 01:08 AM
Tusc's Avatar
Tusc
Excellent.
Those Z pieces will be on the car before too long. And if I DO wait too long, well, they may end up being StopTechs.
Here she is today after some welding and the new wheels/tires. I just fell in love with the car all over again.
Old May 9, 2017 | 07:08 PM
BRKLYN's Avatar
BRKLYN
Love the wheels and brake set up. What tires did you go with if I may ask? Enjoy....
To Brake Pads
