vettcraz
Old May 4, 2017 | 03:23 PM
vettcraz1's Avatar
vettcraz1
2nd Gear
Default vettcraz
I hav a 99 c5...I installed new plugs(ngk)/wires/(taylor 10.4)...car runs great but has developed a little hiccup or miss whenever at idle in gear...tech chkd codes and said #4 was culprit...changed coil pak and plug(which still looked ok)but problem still persists(note;after I did tune up eng ran great/no issues)any thoughts on what to look at next? thanks
Old May 4, 2017 | 10:57 PM
Moving to C5 Tech.
Old May 4, 2017 | 11:02 PM
StingrayRebel's Avatar
StingrayRebel
have the tech ohm the plug wires
Old May 4, 2017 | 11:55 PM
grantv's Avatar
grantv
Problem persists... did the #4 still show a fault after the fix? I was initially thinking a cracked plug.
To vettcraz
