Start up problems???
Old May 7, 2017 | 01:17 PM
BRZI's Avatar
BRZI
St. Jude Donor '12
Default Start up problems???
My car (2002 Z06) has been running great but recently developed an issue were when i put the key in the ignition and go to turn it to turn the car on nothing happens. The car does not crank at all. The battery is full, and all electronics work fine. I also tried using the other key but same result nothing happens. After turning it over a couple times over and over it finally will turn on and the car runs fine and turns on fine after that. Then a Couple days later it will happen again. Really sucks because i don't feel confident in taking the car out because will be scared i won't be able to start it up. Has anybody had this issue and possibly know what it is?
Old May 7, 2017 | 01:22 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Have you read Bill Curlee's Sticky ......
Could be a dirty Ing. Switch & or grounds.
See sicky's above, lots of info...........
Sticky Thread Sticky IMPORTANT ELECTRICAL INFORMATION (Long!)
Old May 9, 2017 | 01:13 PM
BRZI's Avatar
BRZI
St. Jude Donor '12
I drove the car all day Sunday and could not get the problem to replicate itself. I am not to mechanically inclined I will have to take it to someone to check it out.
Old May 9, 2017 | 02:22 PM
johnnyzvette's Avatar
johnnyzvette
Sounds just like the problem i had a couple of years ago, new starter solenoid fixed it.
To Start up problems???
