Car doesn't start right up
Old May 8, 2017 | 12:15 PM
Big Vig's Avatar
Big Vig
Default Car doesn't start right up
Hello, I have a 2000 C5 M6. Short story thought fuel pump was going out so I replaced it. Turns out it was my chip in the key causing me the problems. Also my car isn't stock and the stock fuel pump was at 90% duty cycle. The new pump I put in didn't flow as much as the stock one. So I put the old pump back in and now it doesn't start right up. It cranks over just fine but takes a little to start. It does it when it's hot and cold. Car runs and drive perfect once it's started. I'm gonna check the fuel pressure tonight but I didn't know if you guys suggested checking other things. I hear the pump prime when I turn it to run.
Thanks Brandon
