I am replacing the water pump on my ls1. I heard the ls3 is a bolt on upgrade. Anyone have any information on this? I am aware I need to buy a new thermostat and housing to get this to work.
When I look up part numbers for the ls1 the ls2 and ls3 I get all different part numbers. I like the ls3 pulley setup better. Just want to make sure I get the correct parts before I tear it all down
Saturday, I just bought a water pump for my 01 MN6. LS1
no modifications..........part number at O'reilly's is CP5081 new with lifetime warranty
I used my old t stat. from the original pump. 83,000 miles
Used the O ring that came with the pump. had pressure against the housing like the old one. 160
T stat opens like it always did.
You cannot buy the old style LS1 water pump any longer. Hasn't been sold in over 10-12 years. If you are replacing a water pump on your LS1 the only choice is the newer LS2/LS3 pump which as you noted does require a new style T'stat and T'stat cover............
What is the difference in them? When I did my build last year I think I got an Old style one (re-man). The T'stat is separate from the water neck and the back is bolted on. The one I took off had the T'stat built into the neck. The back cover was a big plug.
I recently had the original pump replaced on my 98 with one purchased from Rock Auto that looks exactly the same as the original. Also put a new T-stat in and used the original T-stat neck. Here's a pic of the one I picked up from Rock Auto
Thanks 8VETTE7 I got a remanufactured old one, I think. It was easier to find a 160 deg thermostat for being that it was separate from the neck. According to the links, the old one may have been the '04 style.
