Fuel Gauge
Old May 11, 2017 | 04:03 PM
randy@embarqmail.com's Avatar
5th Gear
Default Fuel Gauge
Just replaced both left and right fuel pumps and sending units in my C5.
but the gas gauge only goes to half full and very slowly. Any answers to correct.
Old May 11, 2017 | 05:16 PM
StingrayRebel's Avatar
StingrayRebel
did you install the level sensor properly?... it's real easy to get it tangled up which would prevent it from showing the correct level on your gauge
Old May 11, 2017 | 06:32 PM
5th Gear
Don't know, had a mechanic do it at the chevy garage. What should be looked at. He said it could be the screed that is blocking the float arm. We thought that driving it might free it up. I guess I need to know what installed properly is. This is why I changed everything to get the gauge to operate correctly.
Old May 11, 2017 | 07:54 PM
69's Avatar
69
Cruise-In VI Veteran
Hello,
My assumption from you post is that your fuel gauge goes from “E” to “1/2”? If this correct, than you need to focus on the right/passenger side fuel tank sending unit as the right/passenger side fuel tank sending is responsible to move the fuel gauge needle from “1/2” to “FULL”.
Recommend the following actions;
Post up any and all codes logged in the DIC to this thread, upon recording (writing down all the codes) clear all codes in the DIC.
Perform a detailed visual inspection on the right/passenger side fuel tank sending unit electrical plug/wiring to ensure that there are no issues, (IE is the sender electrical plug fully seated and locked in the sender???
As you have no reference to the model year car you have, it is very important to post up the year of your car as there are variances to the C5 Model years on how the fuel level indication system is integrated in to the car…Year of your car?
If after you perform a detailed visual inspection of the right/passenger side fuel tank sending unit electrical plug/wiring and NO issues were found, proceed as follows;
Remove the right/passenger side fuel tank sending unit electrical plug and check the sensor to see if it is actually reporting fuel levels to the PCM using a Ohm meter
Check out my fuel table post in this thread for troubleshooting a "99 Vette that has detailed instructions, POST #18
https://www.corvetteforum.com/forums...h-sensors.html
Post up what you find and/or readings for further troubleshooting.
Cheers,
Goose
Old May 11, 2017 | 08:52 PM
don37's Avatar
don37
Veteran: Canadian Forces
Good luck! Subscribed.
Old May 12, 2017 | 04:43 AM
5th Gear
Strainer not screed sorry
Old May 12, 2017 | 04:44 AM
5th Gear
Originally Posted by 69
Hello,
Cheers,
Goose
It is a 97 c5
Old May 12, 2017 | 04:45 AM
5th Gear
97 c5
Old May 12, 2017 | 08:03 AM
69's Avatar
69
97 c5
Thanks for posting up that you have a 1997 model year;
The 1997 right/passenger side fuel tank requires a “3 wire capable” fuel level sensor for the indication to work correctly in the 1997 model year car.
Can you please confirm if your Chevy Tech installed the following part number fuel level sensor?
Fuel Pump and Level Sensor Module with Seal and Bolts
AC Delco Part Number: MU1216
Product Notes:
Fuel Pump and Sender Assembly
All; IMPROVED SENSOR CARD
Per Vehicle: 1; Years: 1997-1999
http://parts-catalog.acdelco.com/cat...log_search.php
In the below link , I was working with A CF member sorting out his 1997 and I posted photos/schematics showing the variances between the 1997 and 1999 model year cars which at the end of the day the wrong part number sender was installed in the right/passenger side fuel tank of his car, which caused his issue….
https://www.corvetteforum.com/forums...ding-unit.html
Post#4
Post#24
Post#33
Post#38
Way forward>
Q1) Post up your DIC codes to this thread.?
Q2) As the 1997 requires the “3rd wire” for the fuel gauge to work correctly, Verify the part number and manufacture (OEM?) of both left/right fuel level sensors that were installed by your Chevy Tech and post to this thread.?
Q3) Post up the results of the wire/connector detailed visual inspections, are there any “findings/discrepancies”?
Upon posting up your answers to the above questions with no “findings/discrepancies”, we can go to the next level of troubleshoot by way of performing continuity/Ohm checks using a digital multi-meter (DMM).
Cheers,
Goose
To Fuel Gauge
