Replacement CV axle/half-shaft advice
Old May 13, 2017 | 05:39 PM
gallonoffuel's Avatar
gallonoffuel
Default Replacement CV axle/half-shaft advice
Hey all,
I recently discovered a tear in the outer CV boot of my 2000 Coupe, and the subsequent grease shower all over everything near it. From my research, I believe I have 3 options.
  1. GM OEM Replacement outer boot - the cheapest option
  2. Remanufactured axles from an auto parts store
  3. GM OEM complete axles - the most expensive option
The car is 17 years old so replacing only 1 boot seems like I might be doing this again someday. The inner boots are not available either, from what I see. I've heard that the remanufactured axles have boots that are softer than OEM and will balloon at high speed. I've started doing track days and the car routinely sees 130mph+. Complete axles are almost $600 for the pair, but I don't have any reason to believe the axle I have is contaminated since I inspect the car fairly regularly.
Are these all of my options?
Old May 13, 2017 | 09:03 PM
StingrayRebel's Avatar
StingrayRebel
a used set of c5z axles can be had for pretty cheap, check the for sale forum or get in touch with Marc at vettenuts
Old May 14, 2017 | 11:30 AM
feeder82's Avatar
feeder82
This one is a cheap aftermarket boot
this is the factory boot, the number of pleats in the boot is the big difference, its much stiffer.
I would just replace the boot with a genuine GM boot and be done with it.
auto part store axles have the cheap boots
Old May 14, 2017 | 12:01 PM
gallonoffuel
This is super helpful, thank you! I think I will replace both outer boots while I have everything apart and make sure everything is clean and well greased. If the inner boots end up leaking I will have to figure something else out. Thanks!
Old May 15, 2017 | 04:26 PM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have them in stock with new gm boots and new grease in OEM axles.
Old May 15, 2017 | 05:07 PM
gallonoffuel
Is there a part # for these on the website? SKU 855 does not mention having new boots or grease. Thanks!
Old May 17, 2017 | 09:08 AM
edmundu's Avatar
edmundu
I just bought a pair a week ago, both came with old grease & boots.
Old May 17, 2017 | 09:09 AM
edmundu's Avatar
edmundu
Really?
I just spoke with you on Monday, and was told you had no clean lo mileage axles in stock...
To Replacement CV axle/half-shaft advice
