Help Code!
Old Sep 28, 2002 | 04:33 PM
edv2122's Avatar
edv2122
Default Help Code!
under 60 IPC got a code U1064H
What does it mean? Should I be concerned?
No check engine lights or anything I just scrolled through the diagnostics and I saw that code pop up.
Does anyone know what this means? I have a 03 Z06 :confused:
Old Sep 28, 2002 | 04:45 PM
Rookiedyn's Avatar
Rookiedyn
Default Re: Help Code! (edv2122)
I am no expert but I do have a list of codes as I have been attempting to educate myself more. The code you listed is an older code (H) history. And comes back..
U1064 Loss Of Communication with DCM
I am sure one of the pros will post with more information.
Old Sep 28, 2002 | 06:00 PM
kh24's Avatar
kh24
Have you disconnected your battery recently? If so that is what caused the code. :cheers:
Old Sep 28, 2002 | 06:07 PM
G 99's Avatar
G 99
Codes U1016, U1064, & U1096 occur from time to time. It just means there was a short disconnect from the pcm or bcm.
No worries...it happens. :cheers:
Scott
Old Sep 28, 2002 | 11:26 PM
edv2122's Avatar
edv2122
Default Re: Help Code! (Chandlerdah)
Thanks guys. I will reset the code. :cheers:
To Help Code!
